New OPPO DV981HD !!!
16 June 2006
7,335
127.0.0.1
Βγηκε επιτελους με ολα τα καλουδια του 971 (λεγε με farοudja) και φυσικα με 1080p upscaling και με HDMI και SACD ....
OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
DVD-A/SACD Playback, HD Up-Conversion with DCDi by Faroudja Video Processing and HDMI Output
Universal DVD Player Features:
  • DVD-Audio, Super Audio CD (SACD) and DVD-Video universal playback
  • Compatible with Audio CD, HDCD, WMA, Kodak Picture CD, and other digital audio/video/picture media and formats
  • Official DivX� Certified product, certified to the Home Theater Profile
  • Plays all versions of DivX� video (including DivX� 6) with standard playback of DivX� media files
  • Plays XviD and .SRT, .SMI, .IDX and .SUB format
Video Up-Conversion Features:
  • High definition up-conversion with film-like picture quality to up-convert 720x480 interlaced video encoded on DVD discs to 480p/720p/1080i and 1080p
  • DCDi by Faroudja video processing technology with progressive scan, film mode detection, TrueLife™ enhancement and motion adaptive noise reduction.
  • Video is analyzed on a single pixel granularity to detect presence or absence of angled lines and edges, which are then processed to produce a smooth natural looking image without visible artifacts (jaggies)
  • High-quality pure digital video and audio through a single HDMI (High Definition Multimedia Interface) cable
  • Multiple high definition video formats through HDMI output: NTSC: 480p/720p/1080i/1080p; PAL: 576p/720p/1080i/1080p
  • Compatible with HDTV, HD-Ready TV, HDTV monitors and projectors with an HDMI or DVI input
  • Direct PAL/NTSC disc and TV compatibility and system conversion
  • For more information about DVD video up-conversion, please read our white paper article Getting the Most out of DVD on an HDTV Display
  • Supports screen aspect ratio 4:3 (standard) and 16:9 (wide-screen)
  • User adjustable video controls: Sharpness, Contrast, Brightness, and Saturation
  • Composite video and S-Video outputs (standard-definition output only)
Optimized Audio Features:
  • High-resolution multi-channel digital audio output through HDMI supporting CD, DVD-Audio, SACD, Dolby Digital and DTS sound tracks.
  • Individual analog 5.1-channel surround and down-mixed stereo outputs
  • 24-bit, 192kHz high resolution audio D/A converters
  • Optical and coaxial digital audio outputs with DTS, Dolby Digital, Dolby Pro-Logic II and Linear PCM support
  • 3D Surround (Virtual Surround): Concert, Live, Dance, Techno, Classic, Soft
  • Built-in equalizer, channel trim and channel delay functions
Compatibility Features:
  • PAL/NTSC disc and TV compatible with automatic or manual system conversion
  • Compatible with CD-R/RW, DVD±R/RW and DVD+R DL* (* Playability of self-recorded discs may vary depending on media and formatting software types)
  • Dual-laser optical pickup head with excellent error correction
  • Enhanced dual-layer disc support with fast layer change
  • Wide range universal power supply (~100V-240V, 50/60Hz AC)
Convenience Features:
  • Special disc tray - thin, flexible and strong. Can tolerate some bending without breaking.
  • Smooth and easy navigation of photo albums, music collections and video files on DVD and CD
  • Selectable subtitle and audio tracks
  • Discrete ON/OFF remote control IR code for programmable universal remote controls
Connectors:
  • HDMI - High Definition Multimedia Interface: 1
  • Analog Stereo Audio (Mixed 2-Channel Left/Right): 1 group (2 connectors)
  • Analog 5.1 Channel Audio: 1 group (6 connectors)
  • S/PDIF (IEC-958) Coaxial Digital Audio: 1
  • S/PDIF (IEC-958) Optical Digital Audio: 1
  • Composite Video: 1
  • S-Video: 1
  • No Component Video (YPbPr/YCbCr) on the DV-981HD model. This model is designed for use with a display device with HDMI or DVI digital video input.
Accessories Included:
  • High-quality certified HDMI cable with gold-plated HDMI connectors
  • Remote control with "glow in the dark" keypad (batteries included)
  • Stereo audio cable
  • Composite video cable
  • User manual and warranty information
Νίκο όπου νάναι θα βγουν για τα καλά τα hd και blue ray (εννοείται με normal τιμές). Εαν έχεις ένα xbox παίρνεις με 200 ευρώ το hd dvd drive και τελειώνεις.
Το oppo που αναφέρεις πόσο κοστίζει?
Ώχ, πάλι σε πειρασμό θα μπούμε και όχι τίποτα άλλο δεν έχει περάσει μήνας που αγόρασα το 971 και θα πρέπει να το αποχωριστώ. Πάντως εγώ τελωνείο δεν πλήρωσα για το 971 και πιστεύω ότι έτσι θα είναι και γι' αυτό.
Re: Απάντηση: New OPPO DV981HD !!!
Ετσι ειναι. Τελωνειο δεν εχει.
Δυστυχώς δεν είναι ακριβώς έτσι. Επειδή τα ξέρω απο πρώτο χέρι, δεν υπάρχει σαφής διαδικασία ως προς το τι τσεκάρουμε, τι αφήνουμε και με ποιον συντελεστή φορολογούμε την κάθε φορά. Υπαρχει φίλος που δεν πλήρωσε τίποτα, υπαρχει άλλος που πλήρωσε 32 ευρώ και άλλος που πλήρωσε 68 ευρώ. Το να λέμε οτι δεν υπάρχει τελωνείο είναι μάλλον παρα-πληροφόρηση (φιλικά πάντα-bye- )
OPPO DV981HD DVD
Γεια σε ολους.Σας γραφω με αφορμη ενα test που διαβασα σημερα για αυτο το dvd ,με πολυ καλα σχολια απο ελληνικο περιοδικο.
Η ερωτηση μου ειναι αν το εχει δει καποιος να παιζει να μου πει την γνωμη του για την εικονα του ,και ειδικα οταν κανει upscaling σε 1080p.
Re: OPPO DV981HD DVD
Xμμ, ψάχτο λίγο παραπάνω dimitristop.
Δεν το έχω δει στα 1080 αλλά το net "βρωμάει" με πολύ καλά review των Oppo γενικότερα. Θα βρεις αρκετό υλικό.
Έχω το συγκεκριμένο μηχάνημα εδώ και 3 μέρες συνδεδεμένο με την SONY 40w2000...
Η αγορά του έγινε με το σκεπτικό του να βλέπω "Αξιοπρεπώς" τα DVD που έχω μαζέψει εδώ και χρόνια. To upscaling που έκανε η TV δεν με ικανοποιούσε, και δεν ήθελα να δουλεύει το PC (επίσης συνδεδεμένο με την TV) για να δω ένα DVD.
Η αλήθεια είναι ότι το upscaling (1080p) που έκανε η TV δεν μου άρεσε αφού πριν έβλεπα HD trailers και ταινιούλες!
Δοκιμάζοντας το Oppo στα 1080p σε διάφορα DVD (κυρίως χαμηλής ποιότητας) αλλά και νοικιάρικα: τα βλέπω μια χαρά και με αρκετή λεπτομέρεια...
Αν στο DVD (υπάρχει καλής ποιότητας υλικό) [δεν μπορώ να το όρισω ωστόσο] τότε πραγματικά μένεις με ένα μεγάλο χαμόγελο...!
Χρειάζομαι ακόμα αρκετό χρόνο όμως για να το ξεψαχνίσω και να δω περισσότερα καλά (ή και τυχόν αδυναμίες)...
Ακόμα έβαλα και την πρώτη ταινία που βρήκα σε DivX, από το έτος 1997, οπότε με αρκετά προβλήματα στην κωδικοποίηση από πλευράς ποιότητας... αλλά όλα φαίνονταν μια χαρά.
Υποχρεωτικά πρέπει να κάνεις update το firmware του μηχανήματος ώστε να βλέπεις ελληνικούς υπότιτλους (το οποίο προμηθεύτηκα από εκεί που το πήρα).
Ελπίζω να βοήθησα...
μήπως είδες διαφορά σε αναπαραγωγή DIVX/XVID?
δηλαδή ρωτάω αν "προσπαθεί" να κάνει upscaling σε MP4 avi's
Απο codecs τι διαβάζει?
Μόνο το παλιό DivX και ένα πολύ πρόσφατο Xvid έβαλα να δω...
Θα κάνω κάποιες δοκιμές το Σαββατοκύριακο βλέποντας και τις διάφορες version των κωδικοποιήσεων.
Λογικά θα πρέπει να κάνει upscaling προς 1080p σε οτιδήποτε έχει χαμηλότερη ανάλυση.
(Τι κρίμα να μην έχει και μια USB...)
OPPO 981
Μόλις το παρέλαβα και θα το συνδέσω το βράδυ με τον επσον 600 μεσω HDMI για εικόνα και οπτική για ήχο.
Θέλω να ρωτήσω αν υπάρχει κάποιος κάτοχος ή κάποιος που το ξέρει, αν υπάρχουν default ρυθμίσεις που πρεπει να κανω, μια και φαντάζομαι έχει πολύ περισσότερες από τα συνηθισμένα πλειερς και δεν θέλω να χαθώ...
Επίσης σε παλιότερα θέματα είχαν αναφερθεί καποια ερωτήματα σχετικα με προβλημα με το Macroblock... τι είναι αυτό και αν εξακολουθεί να υφίσταται.
Αν παίζει απροβληματιστα όλα τα δισκάκια... (νοικιάρικα, αντιγραφα ασφαλείας, +, -, όλες τις μάρκες κτλ.)
Ο Μπάμπης Κολέζας είχε αναφέρει παλιότερα ότι το DCDi δεν είναι και ότι καλύτερο για HD. Είχαν ρωτήσει κι άλλοι τι ακριβώς εννούσε αλλά μάλλον δεν το είδε... αν διαβάσει το θέμα ας απαντήσει αν θέλει...
Αυτα προς το παρόν.
Re: OPPO 981
Η πρώτη εντύπωση θετική, χωρίς Α-Β σύγκριση με κάποιο άλλο έχω την εντύπωση ότι με τις default ρυθμίσεις αποδίδει πιο έντονα/κορεσμένα χρώματα, καλύτερη/ξεκούραστη κίνηση και μάλλον καλύτερη λεπτομέρεια.
Το σίγουρο είναι ότι έχει εξαλειφθεί το φαινόμενο του cropping στην εικόνα που είχα μέχρι τώρα όταν έδινα 720p και δεν έχω εκείνα τα "σύννεφα/πέπλο" που ήταν έντονα ορατά στα λευκά γράμματα στους τίτλους όταν προβαλλόταν σε μαυρο φόντο.
Τα ρυθμιστικά brightness/contrast του πλειερ περνάνε όλη την πληροφορία στον προβολέα αλλά θέλει λίγο ψάξιμο και συνδυασμό με τις ρυθμίσεις στον προβολέα για να έρθουν στα ίσα.
Το χειριστήριο άψογο με γρήγορη απόκριση.
