Sharp Aquos LE600/LE700: Reviews - Εντυπώσεις - Σχόλια
Yperion
21 June 2006
43,515
BVR (Beyond Visual Range)
Το πρωτο review της LE600 απο το CNET...
Sharp Aquos LE600
Yperion
21 June 2006
43,515
Re: Sharp Aquos LE600/LE700
Yperion
21 June 2006
43,515
Δεν έχουν local dimming. Η LH9000 έχει.
Και στα 2 video παραπανω λεει οτι εχει local dimming , το ιδιο λεει και το τεστ του cnet...
Kατω video 2:19 "i see some auto dimming going on there"...
Πανω video 0:34 "if there is black on the screen the LED goes out..."
gzoun
8 March 2008
1,958
Αθήνα-Μενίδι
Απάντηση: Sharp Aquos LE600/LE700
Sharp introduce LE600 LED TV's to the UK
A variation on the LE600's locally dimmed LED TV's with white LEDs, introduced RGB arrays. RGB LED's use red green and blue to produce an expanded colour gamut. The combined light output from red, green and blue LEDs also produces a more pure white light than is possible with a single white light LED setup.
http://hdtvorg.co.uk/news/articles/2009092101.htm
Yperion
21 June 2006
43,515
Re: Απάντηση: Sharp Aquos LE600/LE700
Πρωτη δοκιμη απο flatpanels....
http://translate.google.co.uk/trans...full&id=1253692426&sl=da&tl=el&hl=en&ie=UTF-8
Σε αυτο το τεστ λεει οτι δεν εχει local dimming , τελικα ο καθενας λεει τα δικα του...παντως και στο Avforums που κοιταξα και εκει λενε οτι δεν εχει local dimming...-bye-
Yperion
21 June 2006
43,515
Αυτο ειναι το σημειο που με μπερδεψε....
Direct LED backlighting, with the LED array positioned right behind the screen, is generally considered to enable better pictures than edge lighting because it supports local dimming. In other words, since direct LED-backlit TVs can control the light output of individual LED clusters within the picture, you can have a really dark picture part sitting right alongside a really bright picture part in a way that's simply not possible with ordinary LCD TVs or LED-edge-lit TVs...
http://reviews.cnet.co.uk/televisions/0,39030218,49303787-1,00.htm
MANOS
Inactive User
1 July 2007
1,780
Η ίδια η Sharp λέει ότι δεν έχει. Άρα δεν έχει. Απλά...
Yperion
21 June 2006
43,515
Εχει γινει μπερδεμα σε πολλα site απο οτι φαινεται...
Η σειρά LC-LE700 παρέχει σάρωση 100Hz και οπίσθιο φωτισμό με φωτιδιόδους LED (άσπρες) σε διάταξη Direct-LED πράγμα που σημαίνει ότι παρέχει Local Dimming, ενώ η σειρά LC-LE600 έχει σιαμαία χαρακτηριστικά με βασική διαφορά ότι η σάρωση πέφτει στα 50Hz.
http://www.fullhd.gr/lcd-tv/2008-03-05-01-46-47/1944-sharp-lc-le700-a-lc-le600.html
GeoGeoGeo
28 March 2007
3,498
λαθος του μανου,φαινεται οτι μονο τις samsung προσεχει να γραφει σωστα
greekzero
21 October 2007
263
Άλιμος
σήμερα παρέλαβα την LE700 και η τηλεόραση είναι πολύ καλή.σε σχέση με την z5500 που και αυτήν την κατέχω είναι ασύγκριτη.φοβερα χρώματα με εξαιρετική κίνηση σε ποδόσφαιρα και bluray movies.εκεί που χάνει λιγάκι είναι στο αναλογικό σήμα,αλλα βασικός ρόλος είναι ότι δεν έχω καλή κεραία.μέσο nova τα αναλογικά κανάλια είναι εξαιρετικά αλλα με κεραία όχι και τόσο καλα.η τηλεόραση δεν έχει ίχνος backlight bleedibng η clouding.Σύνδεση με pc και μια nvidia 280 και εκεί η tv είναι άψογη.Με το PS3 έπαιξα COD και PES 2009 και δεν βρήκα ψεγάδια η lag.στη sony μου z5500 βάζω έναν βαθμό 7 και στην συγκεκριμένη sharp 9+
Yperion
21 June 2006
43,515
Η Ζ5500 παιρνει 7 και η LE700 παιρνει 9!!!
Μηπως τα λες αναποδα?-bye-
Αν θελεις βγαλε καμια φωτογραφια να την δουμε και εμεις πως ειναι...-bye-
filosgerou
16 November 2008
74
πάντως στο manual της 46 LE700 αναφέρει μια εντυπωσιακή κατανάλωση της τάξεως των 89W!!! στην λειτουργία εξοικονόμησης ενέργειας
εντυπωσιακό για 46άρα
Isokratis
18 August 2009
1,311
Το review της εντοπιζει προβληματα στην κινηση , κατι που στην Ζ5500 ειναι ενα απο τα πιο δυνατα σημεια της και για πολλους σημειο αναφορας...
Εσυ ισχυριζεσαι το ακριβως αντιθετο???
greekzero
21 October 2007
263
Άλιμος
review = site που παίρνει προμήθεια από άλλες εταιρείες και θάβει άλλες?όχι ευχαριστω δεν θα πάρω .εγώ μιλάω ως ένας ιδιοκτητης τις συγκεκριμένης tv που δεν έχω κάτι να βγάλω από αυτό,απλά να διαφωτίσω νέους αγοραστές..αυτό που είπα είναι το εξής.η sharp έχει καλή κίνηση σε σχέση με την z500 που έχει πολύ καλύτερη.αλα το ότι η sharp δεν έχει καθόλου clouding και backlight bleeding προσωπικά για εμενα την sharp την κάνει καλύτερη tv.
