BenQ W9000 Full HD 1080p Projector
Press Center
Products
BenQ Introduces W9000 Full HD 1080p Projector
Nov 24, 2006
The W9000 features native 1920 x 1080 high resolution, BenQ’s exclusive Seneye™ technology and a whisper quiet 23dB design
TAIPEI, TAIWAN, 24 November, 2006 – BenQ today expands its full HD projector lineup with the BenQ W9000, featuring native 1920 x 1080 high resolution, BenQ’s proprietary Senseye™ technology, Advanced Continuous Electronic IRIS and a superior whisper quiet design that effectively reduces the fan noise to a quiet 23dB, providing exceptional image quality in an undisturbed viewing environment. The W9000 is coupled with HDMI interface and works seamlessly with a wide range of devices including HD DVD players, Blu-ray players and gaming consoles.
The Advanced Continuous Electronic IRIS embedded inside the W9000 brings the contrast ratio to a high 8,500:1 while optimizing the light intensity in bright and dark scenes. The Advanced Continuous Electronic IRIS mimics the human eye’s iris by varying the lens aperture and filtering the scene’s lighting, bringing users high-quality image reproductions.
In addition to its five preset modes, the W9000 now offers more personalized functions with the ISFccc (Imaging Science Foundation Certified Calibration Configuration) of which includes a pair of calibration setting, the ISF Day and ISF Night, for best image quality in different lighting conditions. The settings were configured and locked during installation and requires activation by an ISF certified dealer.
Moreover, the W9000 is compatible with the Panamorph™ lens which converts 16:9 projectors to a full 2.35:1 aspect ratio and increases resolution and brightness by 33% and 20% respectively. The Panamorph™ lens eliminates letterbox bars and works with over 70% of all major motion pictures, offering W9000 users a true cinematic experience.
GeonX
2,755
…κομμάτι ίδια χαρακτηριστικά με τον W10000 της ίδιας εταιρείας… μήπως είναι το ίδιο μηχάνημα και απλώς κυκλοφορεί με άλλο κωδικό σε άλλες χώρες… ? εκτός αν θα βγάλει Hi-End and Midle μοντέλα στα 1080p η Benq…
Browser
10,575
Αρχισαν τα οργανα με τις ιριδες .........χαχα!!
Θα δουμε και ..........βλεπουμε..!!!
23,740
Ακριβώς σαν το menu των Runco.... ;)
Browser
10,575
Παντως αν δειτε στο κειμενο, ο τυπος που το εγραψε , και η εταιρια βεβαια, "χτυπαει" θα λεγαμε απο τη μια τη σονυ και απο την αλλη την αμερικανικη αγορα.
Απο τη μια με την ιριδα, και απο την αλλη με την αναφορα στον παναμορφ.....
Ας ελπισουμε να μην ξεχασουν ουτε την ευρωπη ουτε τα 24 Hz.........
Browser
10,575
Ναι καλα. Γιατι τα αλλα τα 10χιλιρα και τα 16χιλιαρα δεν μας πειραξανε? Η ειναι αληθειες???
Browser
10,575
Ε μετα τι κανανε? Ειπανε παραπανω αποτι ειχαν πει στην αρχη !!
Αλλα και τωρα που λενε 10. Δεκα ειναι???
:flipout:
Browser
10,575
Τι θα εξεταστει βρε? Αν ειναι οντως 10000/1 ο 8720 ?
Πλακα με κανεις?
Browser
10,575
Α, μαλιστα.
Τα ματια μας ειδανε, τωρα περιμενουμε και τα οργανα.
Μανωωληηηηη!!!
takisot
Μέλος Δ.Σ.
27,854
Παλλήνη
Δεν ειναι ολα τα μεγαλα νουμερα παντα μουφα αλλα για να επιτευχθουν χρειαζεται δυναμικη ιριδα.
Πχ ο Pearl μετρηθηκε στα 11.200:1 στο Auto 1 Iris mode και ρυθμισμενος σε D65 απο τον Greg Rogers (WSR) ενω ο Ruby σε 16.700:1. Η διαφορα υπερ του Ruby, αποδιδεται κατα τον reviewer στην τροπο λειτουργιας της δυναμικης ιριδας του Ruby (πιο επιθετικη με αποτελεσμα φαινομενο brightness compression).
Browser
10,575
Thank you Takis.
Απ'οτι φαινεται και κατα οσο καταλαβαινω , μαλλον για εναν μιλαμε τελικα.....
"Τhe W10000/W9000 is one of the very few projectors fully supporting the 1080p/24fps standard,"
ειδωμεν...
takisot
Μέλος Δ.Σ.
27,854
Παλλήνη
Μαλλον οχι:
BenQ W9000 Does 1080p and Ultra-Widescreen
November 24th, 2006
Hot on the heels of the BenQ W10000 projector that was finally released this month, BenQ announced yet another 1080p DLP projector. The BenQ W9000 looks to be the “lite” version of the W10000, probably in attempt to make a more affordable 1080p DLP projector. However, there is one interesting thing to note about the W9000: there is a 2.35:1 Panamorph lens available for it, allowing for the home cinema enthusiast to enjoy true widescreen cinemascope projection. Other than a few custom calibration features and the Advanced Continuous Electronic IRIS which produces a contrast of 8500:1, details are pretty slim. Still, a more affordable 1080p DLP projector with inexpensive 2.35:1 capabilities would definitely be a welcome sight. Careful when we say inexpensive 2.35 though - most panamorph lenses still run about $2,500.
