HD-DVD vs Blue Ray
takisot
Μέλος Δ.Σ.
30,116
Παλλήνη
Απο το http://www.avsforum.com/avs-vb/showthread.php?t=739846 βρηκα το πολυ ενδιαφερον και Up-tο-date post που γινεται μια αντικειμενικη συγκριση των δυο φορμα:
Studio Support (Exclusive)
HD-DVD: Universal, New Line, Warner, Paramount, HBO Films
BD-Disc: Sony, Disney, MGM, 20th Century Fox, Lions Gate, Warner, Paramount
Maximum Disc Size
HD-DVD: 30gb (45gb awaiting future HD-DVD Forum approval for HD Video playback)*
BD-Disc: 50gb (100gb - and up to 200gb theoretical for data storage purposes)*
Hardware Support Consumer Electronics (to date)
HD-DVD: Toshiba, RCA (Toshiba OEM), Microsoft (XBox 360 + HD-DVD Add-On)
BD-Disc: Sony (Pioneer OEM), Sony (PS3), Samsung (Philips OEM), Philips, Panasonic, Pioneer
Current Consumer Electronics Hardware Generation
HD-DVD: Generation 2
BD-Disc: Generation 1
Hardware Support PC (Complete Systems or Laptops)
HD-DVD: Toshiba, HP, Fujitsu, Acer
BD-Disc: Sony, Fujitsu
Lowest Priced Stand-Alone Player (MSRP)
HD-DVD: $499
BD-Disc: $999
Prefered (most commonly used) Video Codec (US)
HD-DVD: VC-1
BD-Disc: MPEG-2
Maximum Potential Bandwidth
HD-DVD: 30Mbps (10 - 15Mbps approx. available overhead using Prefered Video Codec)
BD-Disc: 48Mbps (10 - 15Mbps approx. available overhead using Prefered Video Codec)**
Mandatory Audio Support
HD-DVD: Dolby Digital, Dolby Digital+, TrueHD (2.0), DTS, LDPCM
BD-Disc: Dolby Digital, DTS, LCPCM
Internet/Networking Support
HD-DVD: Standard
BD-Disc: Optional (supported in optional BD-Live specification)*
Secondary Video Decoder (Picture in Picture Features)
HD-DVD: Standard
Persistent Storage
HD-DVD: Standard (128mb - supports additional supplementary storage - USB, etc.)
BD-Disc: Minimal (64k for basic bookmark storage required) (larger storage required for optional BD-Live specification)*
Interactivity
HD-DVD: HDi (based on established web-standards)
BD-Disc: BDJava (Java-based - only required after June 2007 - no discs currently use this feature, so is untested in all players)*
** While controversial, this shows the benefits of using more advanced codecs such as VC-1 and h.264 on BD-Disc, as they can increase the potential headroom and allow for additional features.
Re: HD-DVD vs. BluRay: Αντικειμενικη συγκριση
Τακη ευχαριστουμε για το συγκριτικο, κατ' αρχας.
Προσωπικα η εικονα που ειδα απο το HD της Toshiba στην εκθεση, μου αρεσε περισσοτερο απο αυτην του BR της Pioneer.
Υγ1. Πιστευω (οχι γιατι μου αρεσε περισσοτερο), θα επικρατησει το HD.
Υγ2. Να κανουμε μια ψηφοφορια (εκτιμηση) μεταξυ των μελων, και σε μερικους μηνες οι κερδισμενοι να μπουν σε κληρωση για να κερδισουν καποιο/α HD(ή ΒR), που μεχρι τοτε σιγουρα καποιοι θα μας εχουν (σαν club) προσφερει?
Νομίζω οτι θα επικρατήσει το φορμάτ στο οποίο θα επενδύσουν τα μεγάλα studio του Χολλυγουντ. Επειδή η κατάσταση ειναι συγκεχυμένη δυστυχώς θα περιμένουμε.
Η γνώμη μου ειναι οτι θα επικρατήσει το Blue Ray αλλά οχι γρήγορα. Παντως θα ήθελα να υπάρξει νικητής γρήγορα για να μην ξαναζήσουμε το σενάριο VHS/Beta (και για να επιταχυνθούν οι εξελίξεις...)
Απάντηση: HD-DVD vs. BluRay: Αντικειμενικη συγκριση
Αν σκεφτουμε και πραξουμε με βαση τη λογικη , θα επικρατησει αυτο που θα εχει πραγματικα καλυτερη εικονα και ηχο.
Η μεταβαση στο high definition εχει ενα και μονο σκοπο. Την καλυτερη και σωστοτερη οπτικη και ηχητικη αποτυπωση των ταινιων.
Πιστευω οτι οπου θα παει το αγοραστικο κοινο θα πανε και οι εταιριες. Εαν συμβει το αντιθετο θα ειναι απλα........λαθος απο μερους μας!!
Re: Απάντηση: HD-DVD vs. BluRay: Αντικειμενικη συγκριση
Σου θυμιζω οτι πριν πολλα χρονια με την μονομαχια των Beta-VHS-video2000......νικησε το χειροτερο ....
Το καλυτερο που ηταν το 2000 εμεινε στο χρονοντουλαπο της ιστοριας ...και το BETAMAX καταφερε να ξαναγεννηθει εξελισσομενο σε επαγγελματικο φορματ......
Τωρα πως νικησε το VHS ??
Απλα Μαρκετινγκ και πολλες ταινιες για να το υποστηριξουνε.....:award:
Καλα κανεις και μου το θυμιζεις. Ετσι ειναι. Αλλα ο λογος ειναι ακριβως η τελευταια φραση του μυνηματος μου φιλε havoc.
Και μονον αυτη !
Αν δεν επαιρνε κανεις, τι θα γινοταν???
Θεωρητικα, λογω της υποστηριξης των Studios (της sony) και της υψηλοτερης χωρητικοτητας του, θα επρεπε να ειχε νικησει το BR απο το πρωτο λεπτο.
Ομως, το κακο λανσαρισμα του BR (λογω του ανεκδιηγητου πρωτου BR Player της Samsung και το προχειρο authoring των πρωτων BR σε Mpeg2) σε συνδιασμο με το ιδανικο λανσαρισμα του HD-DVD (Αξιοπρεπες player της Toshiba σε φθηνη τιμη και πολυ προσεκτικο authoring των πρωτων τιτλων σε VC-1 codec) ανετρεψαν τα προγνωστικα και τωρα το HD-DVD οδηγει την κουρσα!
Η προσωπικη μου αποψη ειναι πρώτον οτι αυτος ο ανταγωνισμος οφελει τον καταναλωτη διοτι οι Εταιρειες πιέζονται πλεον να δωσουν καλα αποτελέσματα εικονας και ηχου σε προσιτη τιμη ενω η τιμη των δισκων θα διατηρηθεί σε λογικα επιπεδα και πιστευω εν τελει οτι και τα δυο φορμα θα επικρατησουν: απλα θα κατασκευαστουν universal players και το κυριότερο universal discs (σε ενα δισκο και τα δυο φορμα)!
Απάντηση: Re: Απάντηση: HD-DVD vs. BluRay: Αντικειμενικη συγκριση
Εκεί ήταν το μυστικό.
Υποστηρίζω την επικράτηση του HD-DVD ,κυρίως για 1 λόγο:
Δεν χρειάζεται νεες γραμμές παραγωγής δίσκων...Ολες οι γραμμές παραγωγής dvd μπορούν να τυπώσουν HD-DVD μια μια απλή αλλαγή της κεφαλής του μηχανήματος κοπής μήτρας.
Αντιθέτως ,το BR είναι εντελώς νεο φορμά και απαιτεί νεες γραμμές παραγωγής μιάς και κατασκευαστικά διαφέρει πολυ απο τα DVD/HD-VD.
Και άλλος ένας λόγος για τον οποίο θα έπρεπε να υποστηρίξουμε το HD-DVD της Toshiba είναι ότι τα δισκάκια μπορούν να βγαίνουν dual layer και να παίζουν και σε κοινό dvd player (όπως συμβαίνει και με τα SACD τα οποία έχουν και layer που παίζει σε κοινό CD player) γεγονός το οποίο δεν θα μάς υποχρεώσει να πετάξουμε και να αντικαταστήσουμε όλα τα DVD players μας. Θα μπορούμε δηλαδή να έχουμε το HD-DVD player μας στο κυρίως σύστημα, αλλά στο υπνοδωμάτιο ή στο εξοχικό θα κρατήσουμε το παλιό dvd player
Nα πω και εγω την αποψη μου να παιρνα η ωρα. Σιγουρα το BR ειναι καλυτερο βαση προδιαγραφων και εχει μεγαλυτερες δυνατοτητες (οτι χωραει περισσοτερο το καθιστα για εμενα αυτοματα καλυτερο).Προβλεψη ποιο θα επικρατηση δεν κανω, αλλα φοβαμε πολυ κακο για το τιποτα αφου ετσι οπως πανε μαλλον στο home cinema των περισσοτερων DVD θα υπαρχει για αρκετα χρονια ακομα (δεν ειναι χαζες οι εταιρειες που ακομα πλασαρουν νεα player).
