- 17 June 2006
- 3,061
Η Marantz με τον VP4001 κατεβάζει τον πύχη των τιμών και με μια τιμή €4.100 θα προσπαθήσει να πάρει ένα μερίδιο από τους ανταγωνιστές της στην χαμηλή κατηγορία τιμής.
Εξωτερικά πάντως εμένα κα´τι μου λέει για OPTOMA HD72.
Δεν ξέρω τι λέτε εσεις.
Quick update on a new 1280x768 projector I ran across from Marantz. The VP4001
occupies a price point ($4099.99) held by several other popular projector models but seems to offer slightly better specifications; with a 6500:1 contrast ratio and 1200 ANSI lumens. A quick glance at other DLP projectors in this price range reveals that the VP4001 offers a bit more light output than typically found in the 4k to 5k range.
Detailed specifications of the Marantz VP4001:
•Native 1280x768 Resolution
•720p Darkchip3 DLP from Texas Instruments
•Brightness - 1200 ANSI Lumen
•6500: 1 Contrast Ratio
• 5x Speed 6 Segment Color Wheel
•10-bit Video Processing
•ISF CCC (Certified Calibration Control)
•3 Position Selectable Iris
•Inputs for HDMI, DVI, Component Video (x2), S-Video and Composite Video
•Electronic Vertical Image Shift
•Panel Size - 0.65"
•NTSC, PAL, SECAM
•Projection Size - 40" - 300"
•Optics - Marantz Custom
•Panel Size - 0.65"
•NTSC, PAL, SECAM
