Panasonic DMP-BD55 & Sony BDP-S550. Πώς συγκρίνονται.
Παραθέτω εν τάχει τις προδιαγραφές και δυνατότητες του κάθε player, οι οποίες με μια πρώτη ματιά μου φαίνονται ίδιες:
Α. Panasonic DMP-BD55
Video Features
• PHL Reference Chroma Processor Plus
• P4HD (Pixel Precision Progressive Processing for HD)
• Precise Pixel Generation
• 16-Level Motion Detection with Pixel-Based Motion Adaptive
• Diagonal Processing
• Detection of 3:2/2:2 Pull-Down Progressive Processing
• i/p Conversion for 1080p* Playback
• Up-Conversion to 1080p* Playback
* HDMI connection required.
• 1080/24p Playback (Blu-ray Disc™)
• HDMI™ V. 1.3a with Deep Colour and x.v.Colour*1
• 148.5MHz/12bit Video D/A Converter
• Digital Noise Reduction (3D-NR/ Integrated NR)
• Picture Mode (Normal, Soft, Fine, Cinema, User)
• Picture Adjustment (Contrast, Brightness, Sharpness, Colour, Gamma Correction)
Audio Features
• Built-in Dolby TrueHD, Dolby Digital Plus and DTS-HD*2 Decoder
• 7.1ch Analogue Output
• Pure Audio Components
-High Quality 192kHz 24bit Audio DAC
-Electric Capacitor with Polyolefin Sleeve and OFC Lead
-Copper-Foil Film Capacitor
-Ultra-Low-Impedance Electrolytic Capacitor
-Gold Plated Terminal
-Insulator
-High-Speed 50Mbps Optical Output
• 96kHz Surround Re-master for All Formats (BD, DVD, CD, MP3 and DivX)
• Night Surround Mode
• Advanced Surround (V.S.S.) Creates a Surround Effect for BD and DVD from Only Two Speakers (2 Modes)
• Dialogue Enhancer
• Dynamic Range Compression
Output
• HDMI AV Output
• Component Video Output
• Video Output
• Multi Channel Independent Output (7.1ch)
• Digital Audio Output (1 Optical, 1 Coaxial)
• Ethernet for BD-Live and Firmware Update
Convenience Features
• Compatible with BD-Live and BONUSVIEW (Profile 2)
• VIERA Link for Panasonic Blu-ray Disc Product Line-up
• Movie (AVCHD) & JPEG(HD) View with SD Memory Card Slot
• JPEG Slide Show with Music and Transition Effect
• Multi-Format Playback [BD-Video(BD-Live), DVD-Video, DVD-RAM, AVCHD (SD Memory Card/DVD),
DVD-RW, DVD-R, DVD-R (Dual Layer), +R, +R (Double Layer), +RW, CD, CD-R/RW, MP3, JPEG, DivX]
• Super Hi-Speed Scan: 5 Speeds up to x200
• Easy Setting Guide
• Graphical User Interface
• Audio/JPEG Navigation Menu
• Remote Control
Technical Specifications
FORMAT
BD-ROM: BD-Live
BD-RE/BD-RE DL: BD-MV(BD-RE version3) - BDAV (SESF) - JPEG (HD)
BD-R/BD-R DL: BD-MV(BD-R version2) - BDAV (SESF)
DVD-RAM: DVD-VR - JPEG (HD) - AVCHD
DVD-R/-RW/-R DL: DVD Video - DVD-VR - AVCHD - DivX (DVD-R/DVD-R DL)
DVD+R/+R DL/+RW: DVD-VR - AVCHD
DVD-ROM: DVD Video
CD, CD-R/-RW: CD-DA - DivX/MP3/JPEG (HD) (CD-R/-RW)
SD Memory Card: AVCHD - JPEG (HD)
VIDEO
- Precise Pixel Generation
- 16-Level Motion Detection with Pixel-Based Motion Adaptive
- Diagonal Processing
- 3:2/2:2 Pull-Down Progressive Processing
- i/p Conversion for 1080p Playback (via HDMI)
- Up-Conversion to 1080p Playback (via HDMI)
Video D/A Converter: 148.5MHz/12bit
Progressive Scan
Digital Noise Reduction: (3D-NR/ Integrated NR)
1080/24p Playback (for BD-ROM/R via HDMI)
Deep Colour
x.v.Colour
Picture Mode
Picture Adjustment
NTSC Output Selectable
AUDIO
Audio D/A Converter: 192kHz/24bit
Dolby Digital Plus: Decode and Bitstream Output (HDMI connection required)
Dolby TrueHD: Decode and Bitstream Output (HDMI c. r'd)
DTS-HD (Hi-Res + Master Audio Essential): Decode and Bitstream Output (HDMI c. r'd)
96kHz Surround Re-Master: for All Formats -CD @ 88.2 kHz
Night Surround Mode
Dialogue Enhancer
CONVENIECE
VIERA Link (HDAVI Control 3)
Super High Speed Scan
INPUT/OUTPUT
SD Memory Card Slot
Ethernet for Network (for BD-Live and Firmware Update)
HDMI(Output): Support V.1.3a with Deep Colour, x.v.Colour, High Bit Rate Audio
Component Video Output (Y, PB, PR)
Video Output
SPECIFICATIONS
Audio S/N: 115dB
Dynamic Range: 100dB
Power Source: AC 230-240V, 50Hz
Power Consumption: (Approx.) 21W
Weight (kg): (Approx.) 2.6
Dimensions (W x H x D)(mm) (incl. projecting part) (Appr.) 430 x 55 x 249
Συνεχίζω με τα αντίστοιχα του Sony BDP-S550 στο επόμενο post
Sony BDP-S550 features & specs.
B. Sony BDP-S550
Features
- Multimedia guarantueed with BD-ROM/R/RE, DVD-+Video/R/RW, CD Playback, AVCHD Playback
- The ultimate sound experience through 7.1 Channel analogue output and DTS-HD Master Audio decoding capability via HDMI
- Built in BD-Live (Profile 2.0) to immediately access studio-specific online content including trailers, interviews and other extras and enjoy them through your Blu-ray Disc Player.
- 1GB of exchangable storage to save downloaded BD-Live content from the internet
- Quick Start-up mode enables you to enjoy your Blu-ray movies already after just six seconds
- BRAVIA Sync technology makes connecting the players to BRAVIA televisions and Home Theatre systems from Sony a piece of cake
- The new XrossMediaBar guarantuees an easy to understand menu control, simple for everybody to use intuitively all of the players’ functions
- New Precision Cinema HD Upscale technology that converts standard-definition signals (480i) to 1080p and outputs a full HD equivalent resolution signal to 1080p TVs via HDMI
- With 24p True Cinema you can sit back and watch the film like in real cinema, without length or quality losses
- The BonusView functionality allows you to view two separate video streams from the same Blu-ray Disc on screen at the same time
- x.v.Color allows the S350 to output more natural and vivid colours similar to what the human eye actually sees in the natural world.
- New Precision Drive HD helps to detect and correct wobbling discs from three directions, stabilizing playback of bent or scratched Blu-ray Discs and DVDs.
- The back lit remote enables you to control the S550 in the dark without the need to destroy your cinema experience to switch on the lights.
Player Type
Available Colors: Blue & Black
Region Code: DVD 2
Region Code:BD-ROM "B"
System
BD-ROM (BonusView; Profile 1.1)
BD-ROM (BD-Live; Profile 2.0)
BD-R/RE Playback
AVC-HD 8c/12cm DVD Playback
DVD Video Playback
Audio CD Playback
(Does NOT Play VCD/Super VCD)
DVD-R/RW (Video Format) Playback
DVD-RW (VR Format) Playback
DVD+R/RW Playback
CD-R/RW Playback
JPEG Playback
Picture Quality
1080p output (via HDMI)
Precision Cinema HD upscale (DVD upscaling to 1080p)
Video D/A Converter: 12bit/148.5MHz
24p True Cinema
x.v. Colour
Progressive Scan Output
Precision Drive HD
Preset Picture Mode
Audio
8ch Linear PCM bitstream out
Dolby TrueHD decoding
Dolby TrueHD bitstream out
DTS-HD Master Audio bitstream out
Construction
Display on Front Panel
Terminal (Connections)
HDMI x 1
Component Video Output x 1
S-Video Output x 1
Composite Video Output x 1
SCART Connector: NO
Digital Audio Outputs: Coaxial x 1, Optical x 1
7.1ch Analogue Output x 1 set
2-ch Analogue Stereo Output x 1 set
Ethernet x 1
Remote
Backlit remote
TV Control
Convenience
Quick Start-up
XrossMediaBar (GUI)
Easy Set up
BRAVIA Sync
PhotoTV HD
Firmware update via Ethernet
Local Storage for BD-Live (1GB USB Flash Memory)
Child Lock (Tray Lock)
Parental Control
Others
Screen Saver
Audio/Video Bit Rate Indicator
Specifications
Power Requirements: 220-240 V
Power Consumption (in Operation): 29 W
Power Consumption (in Standby): 0.3 W (in Normal Stand-by Mode)
Dimensions (WxHxD): 430 x 70 x 220 mm
Weight (kg): 3.3
Οι τιμές στην Ευρώπη για το πρώτο παίζουν από 399 μέχρι 479 ευρώ (σε κάποια ιντερνετομάγαζα, εκ των οποίων άλλα λένε πως το έχουν σε στοκ και άλλα όχι, ενώ αυτά που λένε πως το έχουν, δεν επιτρέπουν αγορά από Ελλάδα), ενώ για το δεύτερο από 318 μέχρι 439 ευρώ, με τις ίδιες αναλογίες σε στοκ και δυνατότητα αγοράς.
Στην Ελλάδα, το πρώτο εμφανίζεται σε μια μόνο τιμή στα 403 ευρώ, όχι σε στοκ όμως, ενώ το δεύτερο από 399 έως 450 ευρώ (εδώ το στοκ ίσως υπάρχει, δεν είναι ξεκάθαρο - αν και ο γνωστός μας Πανόργιος δεν το έχει εμφανίσει ακόμα).
Ποια είναι η άποψή σας, τόσο για πραγματική σύγκριση σαν μηχανήματα, όσο και σαν σχέση τιμής/απόδοση;
Δημήτρης Ιωάννου
15,854
Αθήνα-Κέντρο
Κατ αρχήν (προσωπική μου άποψη) υπερτερεί ελάχιστα το Panasonic, έχοντας δυνατότητα picture adjustment (που δεν έχει το Sony) και επίσης playback δίσκων DVD DL (που επίσης δεν αναφέρει το Sony).
Μάλλον πάω για Panasonic και επειδή οι αναλογικές έξοδοι δεν με αφορούν ,κλίνω προς το 35 που έχει ακριβώς τα ίδια χαρακτηριστικά και ποιότητα..
Καλή η δουλειά σου πάντως να τα παραθέσεις όλα για σύγκριση.
Εύγε..:grinning-smiley-043
Έχεις δίκιο για τα DVD-DL. Καλή επιλογή το 35.
Έχεις δίκιο για την μη αναφορά αυτής της δυνατότητας από την Sony. Βέβαια, αυτό ίσως να μην σημαίνει τίποτα, μιας και μπορεί στο manual του μηχανήματος αυτό να ξεκαθαρίζεται.
Όμως, σε κάθε περίπτωση, αυτό δείχνει και εάν ο υπεύθυνος για την παρουσίαση κάνει ή δεν κάνει προσεκτική δουλειά στα δύο sites.
Όσο για την επιλογή σου στο 35, είναι πολύ λογική (και θα έλεγα "εξαιρετική"), εφ' όσον βέβαια έχεις τον ανάλογο ενισχυτή-προενισχυτή AV, που θα αναλάβει την αποκωδικοποίηση μέσω HDMI.
Κάτι που εγώ δεν έχω.
να ρωτησω κατι...το 55αρι εχει σκληρο και το 35 δεν εχει η κανω λαθος? το ιδιο δεν ισχυει μεταξυ s350 και s550?εχει νοημα να εχει το μηχανημα σκληρο?
επισης μηπως πρεπει να προσθεσετε στην εξισωση και το P2500 της samsung? φαινεται αξιολογο
JOMARK911
Banned
1,091
ΘΡΑΚΟΜΑΚΕΔΟΝΕΣ
Παιδιά γειά χαρά , απο αυτά που ξέρω , δεν υπάρχει player που δεν παίζει dvd dl , διότι τα περισότερα δισκάκια είναι dl , (ταινίες στα video clubs) ,ως εκ τούτου μάλον ξέχασε να το αναφέρει ο τύπος στην παρουσίαση.
Τώρα το αν έχει picture adjustment το θεωρώ αδιάφορο προσωπικά.
Panasonic DMP-BD55 & BD35 και Sony BDP-S550 & S350
Και τα δύο είναι ΜΟΝΟ players. Από ότι ξέρω, δεν υπάρχει πουθενά στον κόσμο συσκευή που να είναι ΜΟΝΟ player και να έχει σκληρό δίσκο. Η παρουσία σκληρού δίσκου δίνει αυτόματα στην συσκευή δυνατότητες εγγραφής (οποιουδήποτε φορμά, audio ή video), άρα την καθιστά recorder.
Τις διαφορές ανάμεσα στο 55 και στο 35 τίς επεσήμανε ήδη ο Δημήτρης ο Ιωάννου. Η σημαντικότερη (ίσως η μόνη) είναι η ύπαρξη πολυκάναλης αναλογικής εξόδου ήχου 7.1 στο 55, ενώ το 35 έχει μόνο δικάναλη (στέρεο).
Το ίδιο γενικά ισχύει ανάμεσα στα δύο Sony.
Προς Τάσο Οικονόμου
Τάσο, όχι δεν το βρήκα. Δεν έψαξα καν, καθώς γνωρίζω ότι αυτά τα εξωτικά "πρώτης κυκλοφορίας" προϊόντα εδώ φτάνουν με καθυστέρηση κάποιων μηνών. Δεν τα σηκώνει η αγορά, γενικώς.
Σε ότι αφορά στην αναπαραγωγή DVD DL, μάλλον ο φίλος ο JOMARK911 έχει δίκιο. Κι εγώ δεν φαντάζομαι να βγαίνει σήμερα player χωρίς να μπορεί να παίξει DL.
panosxgr
24 June 2006
8,604
Τα Sony δεν τα έχω δει από κοντά, αλλά σαν κάτοχος του DMP-BD30 μπορώ να βεβαιώσω ότι η ποιότητα εικόνας είναι απλά καταπληκτική! Πιστεύω ότι και στα νέα BD35 και BD55 δεν θα πρέπει να έχουν διαφορές τα ηλεκτρονικά τους κυκλώματα.
Re: Panasonic DMP-BD55 & BD35 και Sony BDP-S550 & S350
συμφωνω δεν αντιλεγω...απλα διαβασα στον ηχο για το καινουργιο samsung οτι εχει σκληρο 1GB στην ουσια για αποθηκευσh των upgrades του που θα βγαζει κατα καιρους η samsung και υπεθεσα μηπως το ιδιο ισχυει για για σονυ/πανασονικ
και για αυτο παντως δεν ειμαι 100% σιγουρος, θα το ξαναδιαβασω το αρθρο και θα επανελθω
παντως με 1 GB σκληρο δεν νομιζω οτι το μηχανακι θα λεγεται recorder. ποσα αρχεια να σωσεις σε ενα γιγα?-bye-
-Γιώργος-
19 June 2007
8,441
37°54'25''N-23°45'24''E
Η ύπαρξη χώρου αποθήκευσης τουλάχιστον 1GB είναι υποχρεωτική για τα Profile 2.0 BDP ώστε να αποθηκεύεται υλικό BD Live. Δεν είναι υποχρεωτικό να υπάρχει η μνήμη, αλλά η δυνατότητα τοποθέτησης.
billblack
4 May 2007
66
Προσωπικα θεωρω το χρονικο διαστημα πολυ προωρο για την συγκριση αυτων των 2 κορυφαιων κονσουμεραδικων συσκευων. Σιγουρα συντομα θα δουμε συγκριτικο, αλλα μην ξεχναμε οτι ουτε το ενα ουτε αλλο δεν κυκλοφορουν καλα-καλα στην αγορα.
Παρολο που και εγω προσωπικα ειμαι κατα της Sony, θεωρω το 550 πολυ καλη επιλογη δεδομενης και της προσιτοτερης τιμης του (το βρηκα σε αρκετα internetoμαγαζα στα 399-ακομα και στο Technixx).
Κατα τα Χριστουγεννα θα εχουμε πιο σαφη εικονα για την συγκριση. Τελος, θα ηθελα μεγαλυτερο ανταγωνισμο και απο αλλες εταιρειες (Που είναι η Sharp,LG,Philips,JVC,Samsung -δεν θεωρω το 2500 ανταγωνιστη των αλλων 2). Αυτο θα ριξει και τις τιμες που ειναι ηδη ακριβες. Δεν βλεπουν οτι ερχεται κριση?
billblack
4 May 2007
66
Αν ειναι να παιζει ιδια λεφτα , θα προτεινα να κανουμε μια προταση στο Cnet να τα δοκιμασει για μας.
Δημήτρης Ιωάννου
15,854
Αθήνα-Κέντρο
Απάντηση: Re: Panasonic DMP-BD55 & Sony BDP-S550. Πώς συγκρίνονται.
Sorrry αλλά αυτό δεν είναι απαραίτητο.
Αλλο οι ταινίες παραγωγής και άλλο το εγγράψιμα (και finalized) δισκάκια DL.
Εκεί πολλές φορές πέφτει γέλιο.
Υπάρχουν μηχανήματα (ενίοτε πανάκριβα) που ζορίζονται να τα διαβάσουν-παίξουν.Αλλα πάλι καθόλου.
Προς Θεού,Δεν το παίζω έξυπνος.Συζήτηση κάνουμε και
Ενα προβληματισμό διατυπώνω.Προσωπικά για τα DL δεν με νοιάζει γιατί έχω players να τα παίξουν.
Το picture adjustment όμως το θεωρώ σημαντικό για ταινίες που είναι.."κάπως" σε σχέση με τις reference.Εκεί βοηθάει στο να τις δείς χωρίς να πειράζεις τις ρυθμίσεις του προβολικού σου (τηλεόραση ή προβολέας).
Επίσης το Samsung δεν θα το έβαζα στην ίδια μόιρα και είναι και οφ τόπ[ικ:antlers:
Μνήμη 1GB στα players
συμφωνω δεν αντιλεγω...απλα διαβασα στον ηχο για το καινουργιο samsung οτι εχει σκληρο 1GB στην ουσια για αποθηκευση των upgrades του που θα βγαζει κατα καιρους η samsung και υπεθεσα μηπως το ιδιο ισχυει για για σονυ/πανασονικ
Αυτό που διάβασες ΔΕΝ είναι σκληρός δίσκος αλλά flash memory, γι αυτό και είναι 1 GB μόνο (οι σκληροί δίσκοι αυτού του μεγέθους έχουν εξαφανιστεί από τις αρχές τις δεκαετίας του 90, πριν καν τα Windows 95 κυκλοφορήσουν).
Και όπως επεσήμανε ο g10rg0s, αυτή η μνήμη απαιτείται για την υλοποίηση των διαδραστικών (interactive) λειτουργιών που προσφέρει το profile 2. Το πιο πιθανό (σχεδόν σίγουρο) είναι να έχουν και τα παραπάνω αναφερθέντα φλασάκι για να υλοποιούν το profile 2.
Πάντως και το Samsung μπήκε στο παιχνίδι του ανταγωνισμού, νομίζω. Τώρα το αν θα μπορέσει πράγματι να ανταγωνιστεί τα άλλα δύο, θα το δείξει ο χρόνος. Μην ξεχνάτε πως και η διαθεσιμότητα είναι σοβαρός παράγοντας ανταγωνισμού.
Τέλος για τους δίσκους DL, ο Δημήτρης έδωσε μια καλή εξήγηση, νομίζω.
Θα πρέπει να ξεχωρίσουμε τους όρους. Οι δίσκοι παραγωγής με ταινία από στούντιο δεν λέγονται Dual (ή Double) Layer. Λέγονται DVD-9 και θεωρητικά μπορούν να περιλάβουν περιεχόμενο μέχρι 9 GB. Και το κυριότερο ΔΕΝ είναι εγγράψιμοι. Τέτοιοι βέβαια είναι αυτοί που νοικιάζουμε και από τα videdoclubs.
Οι δίσκοι DL ΕΙΝΑΙ εγγράψιμοι και η θεωρητική τους χωρητικότητα είναι 8.5 GB. Θα μου πει κάποιος: τί 8.5 τί 9. Εμ, αυτό το μισό κάνει τη διαφορά από τους κονσουμεράδικους εγγράψιμους από τους επαγγελματικά κατασκευασμένους σε στούντιο, που είναι οι DVD-9.
Και μάλιστα, ακόμα κι αν είχαμε έναν κενό DVD-9, δεν θα μπορούσαμε να κάνουμε εγγραφή σε αυτόν, γιατί απαιτεί ειδικό εγγραφέα, με δυνατότητες DVD authoring, πράγμα που δεν υπάρχει στα DVD-R drives των PCιών. Στις αρχές του DVD Recording αυτά τα μηχανάκια είχαν από 2500 μέχρι 4000 δολλάρια το ένα. Θυμάμαι μάλιστα ένα της Pioneer (ίσως το πρώτο που κυκλοφόρησε) με τιμή πάνω από 4 χιλιάρικα. Τώρα φαντάζομαι πως θα είναι πιο φτηνά αλλά πάντως δεν τα παίρνεις με 20 και 30 ευρώ που παίρνεις τα άλλα.
Ακόμα, και τα κενά δισκάκια DVD-9, έτοιμα για εγγραφή και DVD authoring δεν είναι καθόλου φτηνά και δεν τα βρίσκεις και εύκολα.
Με μια πρόχειρη έρευνα, που έκανα ωστόσο στο Διαδίκτυο, δεν βλέπω πια να πουλιούνται μηχανάκια για επαγγελματικό DVD authoring. Αντίθετα, πουλιούνται μηχανάκια για BD authoring, τα οποία όμως κάνουν και επαγγελματικό DVD authoring.
Μη φανταστείτε πως είναι πολύ φτηνά, όμως. Το Pioneer BDR-202 έχει 650 δολλάρια μόνο του, αλλά χρειάζεται και software γι αυτή τη δουλειά, οπότε βάλε και καμιά 400αριά για κάποιο από τα softwares (Roxio DVDit, Adobe Encore DVD 2.0, Sonic DVDit, κλπ. -όλα entry level προγράμματα, αλλά επαγγελματικά, μέχρι και τα πανάκριβα Adobe Premikere Pro CS3, Avid Studio Toolkit, κλπ.). Και βέβαια και κατάλληλο εξοπλισμό σε hardware στον υπολογιστή (κάρτες σύλληψης, δυνατό επεξεργαστή, κλπ.)
Για τα παραπάνω (για να μην είμαστε και off topic) μπορείτε να επισκεφθείτε την ιστοσελίδα www.videoguys.com, το σοβαρότερο ίσως ιντερνετικό μαγαζί για επαγγελματίες του video. Εκεί θα τα δείτε - κυριολεκτικά και μεταφορικά - όλα.
billblack
4 May 2007
66
Hitech τευχος Νοεμβριου: Πρωτο τεστ του Sony BDP-S550. Φυσικα και το βγαζει πρωτο. Δυστυχως δεν κανει συγκριτικό με το BD55. Παρόλη την φιλική διάθεση του περιοδικου απεναντι στην Sony, δεν μπορω να μην αναγνωρίσω οτι ειναι μια κορυφαια κονσουμεραδικη συσκευη.
