Τεχνολογίες panel LCD-TFT
Yperion
21 June 2006
43,473
BVR (Beyond Visual Range)
Τεχνολογιες panel LCD-TFT
TN + film
The inexpensive 'TN (twisted nematic) + film' display is the most common consumer display type. The pixel response time on modern TN panels is sufficiently fast to avoid the shadow-trail and ghosting artifacts of earlier production. The fast response time has been emphasised in advertising TN displays, although in most cases this number does not reflect performance across the entire range of possible color transitions. Response times were quoted for an ISO standard black-to-white transition and did not reflect the speed of much more common transitions from one shade of grey to another. More recent use of RTC (Response Time Compensation – Overdrive) technologies has allowed manufacturers to significantly reduce grey-to-grey (G2G) transitions, without significantly improving the ISO response time. Response times are now quoted in G2G figures, with 4ms and 2ms now being commonplace for TN Film based models. The good response time and low cost has led to the dominance of TN in the consumer market.
IPS
IPS (in-plane switching) was developed by Hitachi in 1996 to improve on the poor viewing angles and color reproduction of TN panels. Most panels also support true 8-bit per channel color. These improvements came at the cost of a slower response time, initially about 50ms. IPS panels were also extremely expensive. A partial list of LCDs that utilize IPS can be found at PcHardwareHelp.
IPS has since been superseded by S-IPS (Super-IPS, Hitachi in 1998), which has all the benefits of IPS technology with the addition of improved pixel refresh timing. Though color reproduction approaches that of CRTs, the dynamic range is lower. S-IPS technology is widely used in panel sizes of 20" and above. LG and Philips remain one of the main manufacturers of S-IPS based panels.
Evolution of IPS liquid crystal
AS-IPS – Advanced Super IPS, also developed by Hitachi in 2002, improves substantially on the contrast ratio of traditional S-IPS panels to the point where they are second only to some S-PVAs.
A-TW-IPS – Advanced True White IPS, developed by LG.Philips LCD for NEC, is a custom S-IPS panel with a TW (True White) color filter to make white look more natural and to increase color gamut. This is used in professional/photography LCDs.
H-IPS – Released in late 2006, an evolution of the IPS panel which improves upon its predecessor, the S-IPS panel.
MVA
MVA (multi-domain vertical alignment) was originally developed in 1998 by Fujitsu as a compromise between TN and IPS. It achieved pixel response which was fast for its time, wide viewing angles, and high contrast at the cost of brightness and color reproduction. Modern MVA panels can offer wide viewing angles (second only to S-IPS technology), good black depth, good color reproduction and depth, and fast response times due to the use of RTC technologies. There are several "next-generation" technologies based on MVA, including AU Optronics' P-MVA and A-MVA, as well as Chi Mei Optoelectronics' S-MVA.
Analysts predicted that MVA would dominate the mainstream market, but the cheaper and slightly faster TN overtook it. MVA's pixel response times rise dramatically with small changes in brightness. Cheaper MVA panels can use dithering and FRC.
PVA
PVA (patterned vertical alignment) and S-PVA (super patterned vertical alignment) are alternative versions of MVA technology offered by Samsung. Developed independently, they offer similar features to MVA, but with higher contrast ratios of up to 3000:1. Less expensive PVA panels often use dithering and FRC, while S-PVA panels all use at least 8-bit color and do not use color simulation methods. Some newer S-PVA panels offered by Eizo offer 10-bit color internally, which enables gamma and other corrections with reduced banding. PVA and S-PVA offer good black depth and wide viewing angles and S-PVA also offers fast response times using modern RTC technologies.
Πηγη: http://en.wikipedia.org/wiki/TFT_LCD
Πως λειτουργουν οι TFT-LCD...
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
Re: Τεχνολογιες panel LCD-TFT (part II).
Πως φαινονται τα πανελ σε μεγεθυνση:
IPS
ASV
S-PVA
PVA
Eπισημες σελιδες κατασκευαστων για την τεχνολογια και τις μεθοδους κατασκευης:
Samsung:
http://www.samsung.com/global/business/lcdpanel/promotion/Promotion_SPVA.html
Sharp kameyama plant:
http://sharp-world.com/kameyama/index.html
LG Display...
http://www.lgphilips-lcd.com/homeContain/jsp/eng/tech/tech210_j_e.jsp
ΑU Optronics...
http://www.auo.com/auoDEV/technology.php?sec=tftIntro
Chi Mei Optoelectronics...
http://www.cmo.com.tw/opencms/cmo/technology/TFT-LCDx_What_is_itx/?__locale=en
ΙPS alpha...
http://www.ips-alpha.co.jp/en/technology/ips.html
Επιγραμματικα:
Sony , Samsung -> S-PVA
LG , Philips -> S-IPS
Panasonic , Hitachi -> IPS alpha
Toshiba -> S-PVA , S-IPS
Sharp -> ASV
Benq , Acer -> AMVA
Funai , Mirai -> VA extreme
Ολοι οι μεγαλοι κατασκευαστες στα φθηνα μοντελα (πχ. Samsung σειρα 4 , Sony U + Ρ , Philips σειρα 5 , Toshiba C κτλ.) χρησιμοποιουν πανελ AU Optronics και Chi Mei που προερχονται απο Ταιβαν και Κινα αντιστοιχα.
Eνα καλο site για ενημερωση για τις τελευταιες εξελιξεις...
http://www.displayblog.com
Η Toshiba σε 32''-37''-42'' χρησιμοποιεί τα S-IPS (της LG) ή τα IPS alpha (Panasonic) ?
Υ.Γ Γιατί δεν χρησιμοποίησες το παλιό νήμα ? Έχεις βάλει και στο άλλο σημαντικές πληροφορίες.
Zητησα απο τον Πανο να το αντικαταστησει με αυτο γιατι περιεχει πληροφοριες που πλεον ειναι ξεπερασμενες.-bye-
Η Toshiba εχει αποσυρθει απο την IPS alpa.
Tα πανελ που χρησιμοποιει ειναι απο τις φθηνωτερες προς τις ακριβοτερες τηλεορασεις ΑUO - LG - S-PVA.
Το ξέρω πως έχει αποσυρθεί, απλά νόμιζα πως χρησιμοποιεί τα IPS alpha.
Μικρή η διαφορά αφού έτσι και αλλιώς σύντομα θα χρησιμοποιεί ASV :D
Τα ASV προφανως θα ειναι στα ακριβα μοντελα. Στα φθηνα ειναι αυμφορη η χρησιμοποιηση ενος ακριβου πανελ οποτε η συνεργασια με την ΑUO προφανως θα συνεχιστει.
Απάντηση: Τεχνολογιες panel LCD-TFT (part II).
Το θέμα έγινε sticky, οπότε σας παρακαλώ να μην ξεφεύγει πολύ η συζήτηση εκτός θέματος.
-bye-
Re: Απάντηση: Τεχνολογιες panel LCD-TFT
S-PVA
Color Reproduction Great
Contrast Great
Viewing Angle Great
Motion (Response-Time) Good
AMVA
Color Reproduction Good
Contrast Fair
Viewing Angle Good
S-IPS
Contrast Fair
Viewing Angle Good
IPS-alpha
Contrast Good
Viewing Angle Great
ASV
Contrast Great
Viewing Angle Good
Motion (Response-Time) Great
Απάντηση: Re: Τεχνολογιες panel LCD-TFT
Δεν υπαρχει ξεκαθαρος νικητης.Αν θελεις πχ. οσο το δυνατον πιο γρηγορο πανελ τοτε θα παρεις ASV , αν θελεις την πιο μεγαλη γωνια θεασης θα παρεις IPS-alpha κτλ.
Απο τα καλυτερα παντως συνολικα ειδικα επειδη εχουν κορυφαιο μαυρο και δεν υστερουν στους αλλους τομεις ειναι τα S-PVA.
τελικά εμάς τους άσχετους μας μπερδέψατε. Αν δεν θέλουμε μεγάλη γωνία θέασης αλλά μας ενδιαφέρει καλό κοντραστ και γρήγορο response time, προτείνετε ASV? Για 26 ιντσών κάποια συγκεκριμένη πρόταση?
Στις 26" οι πιο πολλες τηλεορασεις εχουν πανελ β' διαλογης. Μερικες εχουν ακομη και TN που συνηθως το συνανταμε σε μονιτορ PC και τα οποια ειναι πολυ γρηγορα αλλα εχουν πολυ μικρη γωνια θεασης και μετρια χρωματικη απεικονιση.
Ισως σε καποιο ακριβο μοντελο ομως να βρεις τα χαρακτηριστικα που ζητας.
Μονο σαν παρατηρηση οτι η Z4500 μετρηθηκε με τα 200 Hz στο off.
Ισως το ιδιο να ισχυει για καποιες Philips (100 Hz στο off) αλλα δεν διεκρινιζεται.
Με τα 100 Hz στο οn το response time πεφτει στο μισο περιπου , ενω με τα 200 ακομη περισσοτερο.
Παλιοτερα ειχα διαβασει οτι συνδεουν PC μεσω VGA και με την χρηση ειδικου προγραμματος βγαινει το διαγραμμα.
Εχω δει και αναλογες μετρησεις σε μονιτορ αλλα οχι τοσο αναλυτικες...
http://www.behardware.com/articles/712-4/lcd-david-vs-goliath-iolair-vs-dell.html
