Mac OS X 10.5.4
Μιχάλης Κορ.
21,651
Πειραιάς
Η έκδοση 10.5.4 του Leopard είναι διαθέσιμη για να αναβαθμίσει το λειτουργικό σας μέσω της γνωστής διαδικασίας αναβάθμισης (Software Update).
Περιλαμβάνει όλα τα παρακάτω :
General
  • Includes recent Apple security updates.
  • Resolves an issue with saving and reopening Adobe Creative Suite 3 files on a remote server.
  • Includes additional RAW image support for several cameras.
  • Addresses an issue that may result in a partially installed X11 application.
  • Improves L2TP VPN client reliability.
AirPort
  • Addresses AirPort reliability issues with 5GHz networks.
  • Addresses AirPort issues that may result in slower performance in Logic Studio or MainStage.
iCal
  • Improves overall iCal reliability for meeting requests, cancellation notices, delegation, and syncing with iPhone.
  • Resolves an issue that prevents deleting an iCal event without notifying the creator.
  • Addresses an issue in which events in all calendars affect availability. A checkbox now enables information-only calendars to be transparent from free/busy lookups.
  • Resolves a UI issue preventing delegated calendars from showing up as a separate window.
  • Addresses an issue with copying and pasting attendees from one event to another.
  • Resolves an issue in which iCal may not delete events after a specified time interval, even when set to do so in iCal preferences.
  • Addresses an issue in which To Dos cannot be marked private.
Safari
  • Addresses a potential performance issue when loading secure web pages.
  • Resolves issues that may be encountered when accessing secure web pages with client certificates that reside on a smart card.
Spaces and Exposé
  • Addresses an issue in which switching from a space with a Finder window keeps the Finder as the active application instead of the application residing in the destination space.
  • Fixes an issue in which dragging an application from the list of application assignments in Spaces System Preferences does not assign the application to the desired space.
  • Resolves an Exposé issue that may result in only a subset of windows being shown.
