Sony KDL40V3000 Review
-Γιώργος-
19 June 2007
8,441
37°54'25''N-23°45'24''E
Από το HDTVtest ... http://www.hdtvtest.co.uk/Sony-KDL40V3000
SUMMARY
Sony KDL40V3000 is an above average LCD television whose biggest appeal is its relatively inexpensive price (for a full HD Sony LCD TV).
PROS
> Smooth 1080p/24 handling without internal conversion nor interpolation
> Excellent shadow detail delineation
> Exquisite high-definition detail from [Full Pixel] 1:1 mapping
CONS
> Calibrated black level not as deep as W3000/ X3500/ Samsung M86/ F86
> Undefeatable auto-dimming when screen is black/ near-black
> Lacks white balance controls in user menu for greyscale calibration
Conclusion
The Sony KDL40V3000 retains some of the best traits we have come to expect from Bravia LCD televisions manufactured by this Japanese electronic giant. It is one of the few LCD TVs on the market that can handle 1080p/24 video signals smoothly without needing to resort to internal 2:3 conversion nor frame interpolation. Also, shadow detail and fine HD detail presentation on the Sony KDL40V3000 rank among the very best any LCD television can offer.
But some compromises have had to be made to achieve the frankly remarkable price of £750 for a full HD 1920x1080 LCD TV... a Sony no less. Calibrated black level on the Sony KDL40V3000 is nowhere near those found on W3000/ X3500 series, which makes the undefeatable auto-dimming all the more obvious and distracting when the content on screen turns black or nearly black for more than a few seconds. White balance controls have been omitted from the user menu so greyscale calibration needs to be performed from the service menu, and the colour gamut is not as accurate as those implemented on higher-range Bravias.
At the end of the day, the Sony KDL40V3000 is an above average rather than outstanding LCD panel, with its biggest appeal being its relatively inexpensive price.
Τα πλαστικά της γύρω γύρω μοιάζουν λίγο στην Panasonic ή ιδέα μου είναι??
Μεχρι το Χαιλι ρεκομεντ ........... εχει αρκετη αλφαβητο ακομα να συλλαβισει.
Εχει καταφερει κανενας να βρει settings για την παραπανω tv? Το hdtvtest δεν αναφερει τις ρυθμισεις που χρησιμοποιησαν και γενικα δεν εχω βρει τιποτα αξιολογο στο net...
Για αναλογική τηλεόραση με μέτρια λήψη (είδωλα) από κεντρική εγκατάσταση κεραίας πολυκατοικίας
Picture Mode : Standard
Backlight : 2
Contrast : 80
Brightness : 30
Colour : 55
Colour Temperature : Warm1
Sharpness : 14
Noise Reduction : Medium
MPEG Noise Reduction : Low
Black Corrector : Off
Adv. Contrast Enhancer : Low
Gamma : Off
Clear White: Off
Live Colour : Off
Colour Space : Wide
Loght Sensor και Power save off
Είναι καταπληκτική τηλεόραση για αναλογικά κανάλια. Δεν μιλάω για σύνδεση με PC κλπ. που είναι υπέροχη.
Έκανα άριστη αγορά για τα χρήματα που έδωσα.
Ποσο την πηρες αν επιτρεπεται?
Omorfo kommati..kai se kalh timh,,,(htan,,den kserw an einai akoma),,,!! ...then tha klisw to magazi,,,na me xwrisei kai h gunaika,,,,,ere glentia mana mou..!!:party:
Sony KDL-40V3000 10bit panel και ΧΜΒ
Ξεθάβω τη σειρά V3000 (έχω την 40" V3000) επειδή ψάχνοντας βρήκα πολλές και αντικρουόμενες περιγραφές στο internet http://www.sonystyle.com/webapp/wcs...10151&langId=-1&productId=8198552921665118447 .
Συγκεκριμένα ενώ η TV δεν έχει XMB μενού (από ότι γνωρίζω έχουν μόνο οι σειρές W και Χ) έχω βρεί παντού διάσπαρτα review που την περιγράφουν όχι μόνο με XMB μενού αλλά και 10bit panel. Επίσης έχω βρεί ατεκμηρίωτες πληροφορίες που περιγράφουν διαδικασία firmware update μέσω ms stick!!!
Πραγματικά εξεπλάγην όταν διαπίστωσα ότι η συσκευή έχει card reader πίσω από την Cam slot!!! Περισσότερα δεν βρήκα και έχω πραγματικά μπερδευτεί!
Μήπως η Sony κυκλοφόρησε τα μοντέλα της σειράς V στην Ελλάδα με διαφορετικό configuration από ότι στην Αμερική ας πούμε;
Έχει κάποιος τηλεόραση της σειράς; Τα ίδια ισχύουν και για KDL-46V3000 είναι παρόμοια!
Re: Sony KDL-40V3000 10bit panel και ΧΜΒ
Ακριβώς.... συνήθως τα Αμερικάνικα μοντέλα είναι πλουσιότερα σε εξοπλισμό και φτηνότερα από τα Ευρωπαικά. Μ@λ@κ3ς εδώ, κατάλαβες?
