Νέα έκδοση VLC 0.8.6d
Μιχάλης Κορ.
21,651
Πειραιάς
Βγήκε νέα έκδοση του 'πολυτάλαντου' αυτού εργαλείου, με βασικό του όπλο την σταθερότητα στο νέο λειτουργικό Leopard.
Αναλυτικά μπορείτε να δείτε εδώ τις αλλαγές :
Various bugfixes:
* Mozilla plugin: supports a reasonable amount of MIME types on Windows
* Linux: Fixed S/PDIF passthrough with ALSA
* Automatic recovery on unexpected stream discontinuity (clock gap) occurrences in input
* Use field order (top/bottom) for correct bob/linear deinterlacing
* Fix invalid free in bookmarks loading code
Windows and Mac OS Binaries
* FLAC Security Update (CVE-2007-4619) to prevent multiple integer overflows
Active X plugin:
* Security update (VideoLAN-SA-0703)
Mac OS X Interface & Port:
* Apple Remote support on Mac OS X 10.5 Leopard with enhanced functionality
* Improved Video Output compatibility for Mac OS X 10.5 Leopard
* Improved behavior of the Fullscreen Controller and mode changes between Fullscreen and Windowed Video Output
* Softened the white flash artifacts that may appear during the transition of two different movies
* Support for current Ogg file formats
NOTE: This release requires Mac OS X 10.4 or higher. Mac OS X 10.3.9 is not supported anymore.
Encoders:
* Improved H.264 encoding speed on Mac OS X
Other changes:
* The automatic updating facility was removed
* You now need to append --m3u-extvlcopt to your command line to enable
EXTVLCOPT options parsing in m3u playlists.
ΑΠΟ ΕΔΩ
