Panasonic DMP-BD30 (Ερωτήσεις - Εντυπώσεις - Reviews...)
  • Αγαπητοί φίλοι και φίλες.
-Γιώργος-
19 June 2007
8,441
37°54'25''N-23°45'24''E
LOS ANGELES CA (October 30, 2007) - Panasonic, a leader in High Definition technology, announced today the introduction of the DMP-BD30, the next generation High Definition 1080p Blu-ray Disc player. The DMP-BD30 is the first Blu-ray player to be introduced with Final Standard Profile, which adds a variety of new and enhanced features to the Blu-ray arena and one that separates the Panasonic Blu-ray player from the rest of the field. Also unique to the DMP-BD30 is the inclusion of an SD Memory Card slot for playback of High Definition content recorded in the AVCHD format. The SD slot also allows for viewing of digital still images recorded to an SD Memory Card.
Final Standard Profile is an advanced function added to the Blu-ray standard, which opens the door to new functions such as Picture-in-Picture (which displays a second image in a sub window) and Audio Mixing (allows the consumer to switch the sound between the main and sub windows).
Gizmodo.com
Τιμή γύρω στα 500$ στην Αμερική.
Edit: Αναφέρεται πως έχει HDMI 1.3B. Τι παραπάνω δυνατότητες δίνει σε σχέση με το 1.3Α ?
=silent=
2 August 2006
11,086
Homeless
Re: Panasonic DMP-BD30 - 1.1 Profile BR Player
1.3Β hdmi καλώδιο αγορασα προσφατα. Αναθεμα και αν ξερω τι παραπανω κανει
-Γιώργος-
19 June 2007
8,441
CNET editors' review
The good: Excellent picture quality on Blu-ray discs; 1080p output at 24 frames per second; DVD upconversion up to 1080p; HDMI 1.3b output; can output Dolby TrueHD and DTS-HD Master Audio in bitstream format; first Blu-ray Profile 1.1 player; SD card slot can play high-def video from AVCHD camcorders.
The bad: No built-in decoding for high-resolution audio formats; no Ethernet jack for firmware upgrades or future interactive content.
The bottom line: The Panasonic DMP-BD30 offers excellent video quality and is Blu-ray Profile 1.1 compliant, but those who want high-resolution audio will need a cutting-edge AV receiver.
apextos
6 February 2008
221
Τέλος ΜΑΙΟΥ θα είναι διαθέσιμο κάπου στα 475 με 490 ευρώ στα μαγαζιά.
YonVog
26 June 2006
249
ΒΟΥΛΑ
Εγω το παραγγειλα από UK και το περιμενω σε καμια δεκαριά ημέρες. Τιμή 380 euros.
VEN_REN
13 September 2007
340
ωραιος....μπορεις να μου κανεις PM την ιστοσελιδα;
ευχαριστω
YonVog
26 June 2006
249
ΒΟΥΛΑ
www.empiredirect.co.uk. Απλά να σας ενημερώσω ότι δεν στέλνει εκτός UK. Εμένα θα μου το στείλει ο κουμπάρος μου που μένει εκεί.
johny1989
17 December 2007
2,573
Απάντηση: Panasonic DMP-BD30 - 1.1 Profile BR Player
ενας φιλος μου το πηρε πριν μια εβδομαδα απο expert
βγηκε καμια αναβαθμιση?
johny1989
17 December 2007
2,573
καλα το μηχανακι γ@μ@ει .ειναι κορυφη.ουτε καθυστερυσεις ουτε τπτ.πολλες ρυθμισεις εικονας οπως το edge enhancer του xe1 και κορυφαιο drc για τους διαλογους απο το κεντρικο,.
YonVog
26 June 2006
249
ΒΟΥΛΑ
Μπορεις να τον ρωτησεις τι firmware version φοραει? Το τελευταιο ειναι το 1.6 που λύνει καποιο πρόβλημα με το LFE
YonVog
26 June 2006
249
ΒΟΥΛΑ
Check the firmware version currently installed in your BD player
Follow the steps below to check the firmware version currently installed in your Panasonic BD player.
Steps
Turn on the main unit.
Press the [SETUP] button on the remote control to open the display menu screen.
Using the Up and Down cursor buttons on the remote control, select the "DISPLAY" tab - "DISPLAY" items will appear.
Press and hold the "STATUS" button on the remote control. While doing so, the current firmware version for your player will be displayed in the lower right hand corner of the screen (e.g. "1.1").
johny1989
17 December 2007
2,573
που να ρωτησω?στο μενου δεν λεει τπτ.με καποιο συνδιαζμο κουμπιων που δεν τον ξερω
johny1989
17 December 2007
2,573
Απάντηση: Re: Panasonic DMP-BD30 - 1.1 Profile BR Player
THX
Steps
johny1989
17 December 2007
2,573
μολις γυρυσα απο συγκριτικο πσ3 me panny 30 και μπορω να πω οτι εχει πιο καθαρη εικονα το panny
johny1989
17 December 2007
2,573
oxι.θα του πω να το δει.
stauros
7 May 2007
8
απο τηλ στην αντιπροσωπεια της πανα εχθες,
εμαθα οτι σε λιγες ημερες θα πεσει η τιμη του κατω απο 400 γιουρο
γιατι λεει ολος ο κοσμος αγοραζει playstation και θελουν να το χτυπησουν
apextos
6 February 2008
221
Δεν το διασταυρωσα αλλά άν είναι έτσι εγώ θα το πάρω. Το 50αρι μάλλον θα είναι αρκετά ποιό ακριβό και δεν με πείθει η διαφορά τιμής σε σχέση με την ποιότητα που θα πάρω.
Ειδικά αν ακολουθήσουν την πολιτκή να έχουν ένα μοντέλο σαν ΤΟΠ και να το δίνουν με μεγάλο περιθώριο κέρδους όπως συνήθως κάνουν.
