Re: NEW SHARP AQUOS XL1 SERIES
Product Features:
46" 16:9 Wide Screen LCD Television
Full HD (High Definition) 1080p with 1920x1080 resolution
Accepts 1080p, 1080i and 720p HD signal formats
2 x HDMI (High-Definition Multimedia Interface) Digital Link for superb digital pictures and sound
Advanced Super View non-reflective LCD panel
truD-HD processing chip
RGB Plus - Primary Red, Green & Blue colours are enhanced by two further shades of Red & Green;
Provides much more natural and realistic colour shades
Optical Picture Control light sensor measures ambient room light and automatically adjusts backlight levels
100Hz double-frame drive recreates images with twice the number of frames;
Ideal for fast moving images or scenes with motion left to right or top to bottom
450 cd/m2 brightness
10,000:1 dynamic contrast ratio for extra deep blacks (Panel Contrast 2000:1)
176° wide viewing angle
Fast 4ms response time
Picture-and-Text
Integrated Analogue & Freeview Digital Terrestrial tuner (DVB-T)
Under mounted speakers with 2 x 15W Output
Surround Sound & NICAM/A2 Stereo
Auto volume controls equalise volume levels of programmes with various sound sources
PC Input allows your computer to be connected to your serve as a large-screen monitor for surfing the web
Connections include: 2 x HDMI, 2 x SCART, 1 x AV In (V/S Video),
1 x Component (Y/Pb/Pr) In,
1 x C.I. Slot, 1 x PC Input (D-sub 15pin), 1 x AV output (Audio Out, S/PDIF)
Power Consumption TBC W, less than 1 W standby
Screen measures (WxHxD) 1137 x 733 x 124.4 mm
Measures (with stand) 1137 x 796 x 309 mm
Weighs TBCkg, TBCkg with stand
Can be wall mounted with optional wall bracket (VESA 600 x400)
Please note; picture for illustrative purposes only
Supplied Accessories:
Remote Control, Tabletop Stand, Power Cable, User Manual
Useful Information:
XL1E Series is available in 52" & 46" screen sizes
