- 17 June 2006
- 2,756
…και βεβαίως και η Sanyo στο χώρο με καινούργιο 1080p προβολικό… D7/C2 Fine panel και πολλές υποσχέσεις για καλές επιδόσεις και χαμηλή τιμή… φέτος τα Χριστούγεννα θα έρθουν νωρίς για πολύ κόσμο
http://www.google.com/translate?u=h...070824/sanyo.htm&langpair=ja|en&hl=en&ie=UTF8
Sanyo, D7/C2Fine panel on-board full HD liquid crystal projector
- “LP-Z2000” of 378,000 Yen. Contrast 15,000: 1
November 1st sale
Standard price: 378,000 Yen
The sanyo electric corporation the full HD liquid crystal projector “LP-Z2000 which loads the D7 panel of the new generation (W)” sells from November 1st. As for price 378,000 Yen. As for body color white.
0.74 The liquid crystal projector which adopts the Epson make panel of the type /1,920×1,080 dot. As for the panel D7/C2Fine of the new generation where strengthening such as improvement of numerical aperture and 12bit conversion of the liquid crystal driver is assured. The downgrade being packed of black the C2Fine panel which improves with the adoption of dynamic contraction control mechanism “variable iris” of new development, contrast ratio 15,000: 1 (“the vivid” mode time) it actualizes. As for brightness 1,200 lumina. As for lamp 165W UHP.
As for the lens new the optical 2 time zoom which was developed (F2.0~3.0) with, projection of 40~300 inch is possible in for full HD image. As for shortest projection distance of 100 types 3m. “Industry highest wide-ranging movement calls possibility”, the top and bottom maximum of 3 pictures (the ±100%), the left and right maximum of 2 pictures (the ±50%) it loads also lens shift mechanism. Also the electromotive sliding shutter has for the lens.
The 14bit gamma compensation circuit is loaded, smooth gradation expression is made possible. Furthermore, you say that efficiency of the new optical system is pulled out to the maximum, loading “new 3D color management”. When adjusting by the fact that transaction of operation is done in the RGB space to which primary color is difficult to receive influence, color adjustment of approximately 2,160 hundred million sorts, former ratio approximately 1,100 times becomes possible.
2 systems it equips HDMI input of version 1.3a correspondence, supports also DeepColor. In addition, D5 and the component (RCA), S image, the composite, analog RGB (the D-Sub 15 pin) each input is equipped at a time 1 systems.
With the adoption of the large-sized/low noise sirocco fan of new development and the cooling efficiency improvement etc inside the substance, “most quiet actualizing the operational sound 19dB which is said in industry”. As for external size 400×346×146mm (width ## depth ## height), as for weight 7.3kg. Remote control belongs.
Home page of □ Sanyo Electric
http://www.sanyo.co.jp/
□ news release
http://www.sanyo.co.jp/koho/hypertext4/0708news-j/0824-1.html
□-related article
<August 23rd>Epson, numerical aperture was raised, “the D7” 1080p liquid crystal panel
- To build in 12bit driver IC, improvement gradation expression
http://www.watch.impress.co.jp/av/docs/20070823/epson.htm
<August 22nd>The full HD liquid crystal projector of Mitsubishi and actual sale 350,000 Yen
- “Dramatic Iris” loading. Contrast ratio 12,000: 1
http://www.watch.impress.co.jp/av/docs/20070822/mitsu4.htm
November 1st sale
□ news release
□-related article
