Pioneer PDP-5000EX
panosxgr
24 June 2006
8,604
Πρόκειται για το νέο μοντέλο της Pioneer στις 50 ίντσες και με TRUE HD panel (1920x1080).
50-inch 1080p Plasma Display
Double the pixel density and resolution in a plasma display. The highest resolution you can get in a 50-inch flat screen - in fact, it's a world-first.
The PDP-5000EX has a resolution of 1920 x 1080 and is capable of displaying the entire range of High Definition sources, including 720p, 1080i and 1080p – this is the first plasma display capable of 1080p.
What this means is that you get the ultimate in High Definition image detail, colour accuracy and fast moving image clarity – made possible by the displays higher pixel count and faster refresh rate (of 720p). Again, the best you’ll find in a 50-inch flat screen.
The PDP-5000EX accepts both standard and high definition sources and will automatically “smart” convert these to give you the highest resolution picture possible.
Main Features PDP-5000EX
Diagonal Screen Size 50-inch / 127cm
HD Ready Yes
Progressive Scan 720p, 1080i, 1080p
Resolution 1920 x 1080
Contrast Ratio 3000:1
Brightness 1000 cd/m2
Power Consumption (in use/standby) 420W / 0.4W
Dimensions (W x H x D) 1282 x 750 x 98 mm
Weight 39.8 kg
Picture PDP-5000EX
# Deep Waffle Rib Structure: This energy efficient design allows each pixel to deliver a more concentrated beam of light, for truer colour and brighter images.
# PUREBLACK Crystal Layer: this forms part of the front glass plate of the panel to dramatically improve dynamic colour and contrast, deeper black colours, and increased brightness.
# Direct Colour Filter for enhanced contrast and accurate colour reproduction. The non-glass filter is bonded directly to the plasma panel reducing light reflection and refraction for a more accurate image.
Dual Screen Mode (PaP) Yes
Digital CTI Yes
Video Processing PDP-5000EX
# PURE Drive 2HD Signal Processing: Digital Video Processing that delivers a low noise, high contrast, and natural colour image.
# i-CLEAR Drive: for accurate colour reproduction - even the most subtle colour differences - and improved grey-scale rendering in dark picture areas.
# ISF C3 Video Calibration System: which allows your plasma to be optimised for your viewing environment.
# Active DRE (Dynamic Range Expander): your picture is continuously adjusted to make use of the panel's superior contrast range.
# Advanced PURECinema which allows film-based material on DVD or even regular TV to be matched with the natural reproduction seen in a movie theatre - originally encoded at 24 frames per second.
# Colour Temperature Adjustment: 5 Settings which allow you to adjust the level of colour to your personal preferences.
# Digital Noise and MPEG Noise Reduction: system settings which allow you to reduce the picture noise, reproducing images true to the original.
Audio PDP-5000EX
# Audio Amplifier: 13 W + 13 W
(1 kHz, 10 %, 8 Ω)
# Surround System: SRS/FOCUS/Trubass
Connection Terminals PDP-5000EX
# DVI (with HDCP)
# 2 x HDMI (with HDCP)
# BNC (AV Component YPbPr or PC RGBHV)
# S-VIDEO
# COMPOSITE
# L & R Audio In
General PDP-5000EX
# Power Requirements:
AC 110 - 240 V, 50/60 Hz
ΠΗΓΗ: http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=12463&taxonomy_id=62-925
PETRAN
20 June 2006
11,063
in orbit
Μακάρι να'χα τα φράγκα... θα την αγόραζα αμέσως... πρέπει να είναι "διαστημική" τηλεόραση...
Yperion
21 June 2006
43,515
BVR (Beyond Visual Range)
Re: Απάντηση: Pioneer PDP-5000EX
Την εχει σε δοκιμη το τελευταιο τευχος του "Ηχος-Εικονα". Μαλον προκειται για την κορυφαια τηλεοραση που εχει βγει ποτε!!! :grinning-smiley-043
Για την ιστορια πηρε την απιστευτη βαθμολογια 4.85/5 ενω η τιμη ειναι 9.000 ευρω.
Γιώργος.Χ
23 June 2006
5,867
Αττική
Για να μην έχουμε αυταπάτες οσοι νομιζου(με) οτι η τεχνολογια Plasma πεθαινει ....
Πραγματικο αριστουργημα, μπράβο και πάλι μπράβο στην Pioneer :award: :award:
Μιχάλης Κορ.
21,475
Πειραιάς
Θα μου επιτρέψετε να γράψω 1 πρόταση άσχετη με το θέμα αλλά έχει γέλιο : πάω στο πράκτικερ το σάββατο κ χάζευα τις τηλ, κ ακούω υπάλληλο να μιλά σε πελάτες εκεί, "η lcd είναι η νέα τεχνολογία, η plasma είναι η παλιά τεχνολογία, δεν βγάζουν κάτι αξιόλογο πια"....!
:fahne90::grinning-smiley-043
υγ: η παραπάνω τηλ είναι Η κορυφαία τηλ αυτήν την στιγμή στην αγορά.
stavros kamoulakos
580
Athens,peristeri
Μιχαλη δεν εχει πωλητες το Πρακτικερ:Banane0: :Banane0: κανενας αποθηκαριος θα ηταν βρε με φιλοδοξιες:flipout: :flipout:
PETRAN
20 June 2006
11,063
in orbit
Οι κ.κ διαχειριστές που είναι να μας πούν την άποψή τους? (ή όποιοι μπορούν να μας διαφωτήσουν περισσότερο?)
stavros kamoulakos
580
Athens,peristeri
Στην Intersys για προπαραγγελια:music-smiley-005: :music-smiley-005: :music-smiley-005:Αντε αν ειμαστε τυχεροι μπορει να κανονισουν και κανα ''power buy'' :flipout: :flipout: :flipout:
PETRAN
20 June 2006
11,063
in orbit
:flipout: :music-smiley-005: :ernaehrung004: :Banane0:
Γιώργος.Χ
23 June 2006
5,867
Αττική
Απο οτι μου είπε πριν από λιγο γνωστός και αμετανόητος αναγνώστης του Hitech, την έχει σε παρουσίαση στο τεύχος που μόλις κυκλοφόρησε με εξαιρετικές κριτικες (δεν θα μπορούσε να ειναι διαφορετικα...)
Γιώργος.Χ
23 June 2006
5,867
Αττική
Μεσα!!! :ernaehrung004: :ernaehrung004:
Μονο πείτε το νωρίτερα να ακυρώσω τις διακοπές (θα τις περάσω στο σαλόνι αγκαλιά με το ... πλάσμα :Banane0: :Banane0: )
7,544
Στην Intersys για προπαραγγελια:music-smiley-005: Αντε αν ειμαστε τυχεροι μπορει να κανονισουν και κανα ''power buy'' :flipout:
Καλημέρα σε όλους!!!
Σας γράφω από την Intersys!!!
μόλις τώρα παρήγγειλα δύο κομμάτια από την 5000 ΕΧ!!!:award: ...ένα για το σαλόνι...κι ένα για το γραφείο μου!!!:fahne90:
Σταύρο!!!:slapface: ...παίζεις με το πόνο μας!!!:slapface: ...μακάρι να μπορέσουμε να την δούμε κάπου!!!:eek:
Βρε παιδιά...τι να πεις γι αυτή την τηλεόραση???:grinning-smiley-043
Απλά μένεις άφωνος και την θαυμάζεις!!!:award:
ΥΓ: το power buy θα ακολουθήσει σε λίγες μέρες!!!:flipout:
Yperion
21 June 2006
43,515
Ειμαι και εγω μεσα για το power buy...:Banane0:
ΥΓ. Ψαχνω συνεταιρο για ληστεια , οποιος ενδιαφερεται ας στειλει PM.:flipout:
stavros kamoulakos
580
Athens,peristeri
Απάντηση: Re: Απάντηση: Pioneer PDP-5000EX
Φιλαρακι εχεις P.M.:flipout: :flipout: :flipout:
Yperion
21 June 2006
43,515
Re: Απάντηση: Re: Απάντηση: Pioneer PDP-5000EX
Ειναι ευκαιρια να αγορασω και εκεινο το Audi Q7 που ηθελα.:music-smiley-005:
Ntinos P
26 June 2006
22,938
και συ εχεις πμ......
PETRAN
20 June 2006
11,063
in orbit
Όταν κάνετε την ληστεία ενημερώστε με να'ρθω με την σειρά μου να σας ληστέψω ετσι ώστε και τα φράγκα να πάρω και να μπορώ να χαίρομαι την tv...
χεχεχε.. ούτε γάτα ούτε ζημιά...
panosxgr
24 June 2006
8,604
Παρακάτω είναι το review στο τελευταίο τεύχος αγγλικού περιοδικού.
