Infocus BigPlay IN82..
3,061
Καιρός ήταν να δούμε από την Infocus ένα νεο προβολέα. Έπρεπε να ξαναστήσει το επιτελείο της μια και οι πλειονότητα των μηχανικών της μετοίκισαν στην Planar.
Introducing the Play Big IN82
InFocus does it again-a home theater projector combining both style and substance, a stunning fusion of precision-tuned video performance and exceptional visual design: the Play Big IN82. The full-HD 1080p IN82 will please even the most demanding videophile. In fact, the IN82 is the highest performance, single-chip DLP home theater projector in InFocus history.
The Highlights
· 1080p DLP DarkChip3 and a native 4000:1 contrast ratio. Texas Instruments® DLP technology is unsurpassed in its ability to deliver deep black levels, pure whites, and subtle grayscale details. Contrast can be boosted to a maximum 12000:1 using the iris.
· Video optimized brightness up to 1500 Max ANSI lumens. The IN82 is bright enough to deliver film-standard, D65K color accuracy in nearly any theater, even with ambient light or daytime viewing. Or, brightness can be reduced to improve black level performance in a dedicated home theater without dimming the picture.
· HDMI 1.3 with Deep Color™ support. The new HDMI standard can display up to 1.07 billion colors for a smooth picture without color band artifacts.
(Deep Color requires HDMI 1.3 compatible media player & source material.)
· Pixelworks™ DNX™ 10-bit video processing. The same outstanding processing, de-interlacing, and scaling performance as the award-winning InFocus Play Big IN7x series.
· Built-in scaling support for 2.35:1 aspect ratio, for a true Cinemascope/widescreen without an external scaler (requires anamorphic lens, available separately).
· Comprehensive connectivity & I/O, including HDMI, DVI, and PC input, screen triggers, RS232, and an IR repeater input.
· InFocus Color Gamut Calibrator and ISF Day & Night presets. Installers can “lock in” optimized calibration settings for clients-an excellent value-add opportunity.
Orders may be placed beginning July 10, 2007, and products will begin shipping in August.
$5499 MAP
Αυτά είναι καλά νέα. Αυτό με το 2.35:1 δεν το κατάλαβα.
Τίποτα μην δίνεις σημασία.... απλά ξεχειλώνει την εικόνα κατακόρυφα οπότε όταν κοτσάρεις τον αναμορφικό φακό μπροστά να περιέχει μέσα όλη την ανάλυση του πάνελ.
Φυσικά δεν έχει lens shift. :frown:
Επίσης, το κατακόρυφο offset έχει αλλάξει σε σχέση με τα άλλα μοντέλα.
τον έχει δει κανείς;
Πάντως είναι ο καλύτερος που έχει και με full HD...
Λοιπόν το εν λόγω μηχάνημα ήρθε στην Ελάδα με τιμή 4.300 και 3.700 για το IN81.
Εντυπώσεις σε λίγο καιρό (μια δόση) μια και τον έχω στα χέρια μου μια μέρα και ακόμη δεν τον έχω ανοίξει.
Καποιες πρωτες μετρησεις απο τον Jason Turk
http://www.avsforum.com/avs-vb/showthread.php?p=11617176
Alright I am crunched for time since I have a big demo tomorrow, so I couldn't do a full calibration. But I ran the standard adjustments and tweaked them. At 6500k setting, it tested about 6380k or so, so pretty darn close out of the box. That is one beauty thing about Infocus. Lots of adjustments in the unit which is also nice. The colors seem from my "Educated" eye to be really close (not oversaturated in the least, although I have to measure for the hue setting...red did seem to lean towards the orange...again, to my eye). BRIGHT! Quite bright with the iris all the way open. With it closed down all the way it drops considerably. I took some quick measurements but I still have more tweaking and real testing to do before I can confirm these are accurate:
Low Lamp, IRIS OPEN 100%: 851 lumens @D65
Low Lamp, IRIS CLOSED 0%: 243 lumens @D65
Hi Lamp, IRIS OPEN 100%: 1144 lumens @D65
Hi Lamp, IRIS CLOSED 0%: 303 lumens @D65
I tested the contrast with IRIS Full Open and Full Closed (they refer to it as 100 for open and 0 for closed). I got 2133:1 on/off and 524:1 ANSI for the open. For the closed, I got 2621:1 on/off and 322:1 ANSI. That last number I have to double check as I am not 100% sure why it dropped so much. But it may be accurate as you can see how much the light output drops with the iris fully closed.
For my testing, I set the iris at "36", which for the screen size I was shooting worked out to the standard 16 footlamberts.
Impressions: Gorgeous image. Tack sharp...really tack sharp. I also had an RS1 and Epson CinemaPro 1080p I was comparing it to and this was WAY sharper.
I'll get my full review with screen shots up this weekend.
Έφτασε και στην Ελλάδα ο IN82…και κάποιο πουλάκι που τον είδε μου είπε ότι είναι εξαιρετικός στα χρήματα που θα βγει… ;)
νέα από Infocus:
DLP video projector news Posted Wednesday, October 3rd, 2007
Viewed 530 times.
InFocus slashes prices of HD Ready projectors
Acclaimed projector brand InFocus has announced that it's knocking hundreds of pounds off its already impressive-value IN78 and IN76 HD Ready projectors.
The Dark Chip 3 IN78 is now £1500 (down from £2,000), while the Dark Chip 2 IN76 is now just £999 (down from £1400). Which makes them both bargains of quite ridiculous proportions, in our humble opinion.
To find out more, contact UK distributor CSE on 01423 359054.
Το μηχάνημα είναι πολύ καλό Χρήστο και μάλιστα εαν είχε αυτόματη ίριδα θα είχαμε και καλύτερο , στα νούμερα, κοντραστ. Πάντως σε ansi contrast, εαν θέλετε να μάθετε, είχε καλύτερο του Dila(σε ίδιες συνθήκες φυσικά).
Re: Απάντηση: Infocus BigPlay IN82..
…δηλαδή έχουμε ΘΕΜΑ ;) (Sorry Chris για το Clopyright ;) ) κάνα νεώτερο για τη τιμή ;)
στην αμερική είναι περίπου 4,000 δολλάρια... -bye-
