Νεες Sony W3000 και Χ3000.
Yperion
21 June 2006
43,473
BVR (Beyond Visual Range)
Ανακοινωθηκαν οι Sony W3000 and X3000 Full HD που αντικαθιστουν τις Sony W2000 και X2000 (λεγονται XBR στην Αμερικη), συμφωνα με την ανακοινωση:
http://news.sel.sony.com/en/press_r...on/flat_panel_displays/lcd/release/30448.html
Βελτιωσεις απο τις σειρες 2000:
  • 100 Hz (120 in USA)
  • dynamic contrast ratio up to 18000:1, depending on model
  • 1080p input, with upconverting on X-series
  • 24 fps "Movie Theatre" display mode
  • xvYCC 10-bit wide color gamut panel
  • Photo TV HD display mode
  • 3 x HDMI 1.3 input, with CEC support (*)
  • optical audio output
  • XMB-style on-screen display user interface styling
  • compatible with Bravia Internet Video Link module
Στην αμερικη κυκλοφορουν απο Ιουλιο και μετα αναλογα με το μοντελο.
Για περισσοτερες πληροφοριες δειτε και εδω:
52" W-series - KDL-52W3000:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921665119487&parentCategoryId=
52" X-series:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=&storeId=10151&langId=-1&productId=8198552921665153949
We glimpsed the future of the Bravia XBR LCD line back in March when Sony showed off the Japanese-only X2550s, and now it looks like that premonition was dead-on, as the nine new Bravias introduced today feature Sony's x.v.Color wide color gamut system, 10-bit 1080p panels, Bravia Engine upscaler, the oh-so-popular XMB crossbar interface, and compatibility with Sony's Bravia Internet Video Link to stream HD video directly to your set over the 'net.
The $4,300 52-inch KDL-52W3000, $3,500 46-inch KDL-46W3000, and $2,700 40-inch KDL-40W3000 all come flossing a standard brushed-metal case, while the XBRs feature Sony's "floating glass" look, Motionflow 120Hz high-framerate technology, and Bravia Engine Pro.
The KDL-46XBR5 and KDL-40XBR5 will drop in August for $4,100 and $3,300, while the KDL-52XBR5 model (pictured) will come out in September for about $5,100. Those looking to burn a little less cash can pick up the XBR4 series with interchangeable bezels -- the 52-inch KDL-52XBR4 will set you back $4,800, while 46-inch KDL-46XBR4 and 40-inch KDL-40XBR4 are $3,800 and $3,000, respectively.
Εngadget
Οντως! Φαινεται να εχουν τα παντα!
Απο ενα γρηγορο διαβασμα η πιο σημαντικη διαφορα αναμεσα στην W και την X φαινεται να ειναι το κυκλωμα, οπως και πριν (DRC MF V1.0 vs DRC MF V2.5). Οποτε με την λογικοτερη τιμη της η W3000 θα σκισει (χωρις cloud ευχομαστε).
Μπράβο βρε Γιάννη για τις ενημερώσεις που μας κάνεις...
Πράγματι φαίνονται φοβερές τηλεοράσεις...
για να δούμε...αναμένουμε...
Eγώ πάντως κρατάω τις επιφυλάξεις μου για τα 100 Hz,αν θα υπάρχει εμφανείς διαφορά,για να δούμε...
H απαντηση εξαρταται απο την χρηση που θα κανεις. Το καλυτερο θα ηταν και τις δυο...:BDGBGDB55:
Το καλύτερο θα ήταν να τις δουμε με τα μάτια μας και να αποφασίσουμε (αφού δουμε εαν υπάρχουν παιδικές ασθένειες κλπ). Το ευχάριστο ειναι οτι με την κινηση της Sony ανεβαινει ο πήχης και για τους υπόλοιπους κατασκευαστές να παρουσίασουν ανάλογες τεχνολογίες...
Πάντως εαν η Pioneer έχει το ΜΑΥΡΟ και την λεπτομέρεια που υποσχεται στις καινούργιες σειρές τις, τότε :firstprize: :firstprize: :firstprize:
Το θέμα είναι οτι είτε Pioneer είτε Sony, θα έχουμε πολυ ενδιαφέρουσα χρονιά ! 18000:1 contrast ???
Κουράγιο αδέρφια !
Λίγο ακόμα σπρώξτε και θα περάσουμε τις 50000:1 :BDGBGDB55:
(Λάλησα ... Συγγνώμη !)
Ούτως ή άλλως άν κάποιο θηλυκό μας αρέσει, ωραίο plasma λέμε ότι είναι και τίποτα άλλο:flipout::flipout:
+1
Δυστυχώς θα σας απογοητεύσω λίγο, καθώς διάβασα σε ένα άλλο φόρουμ, ότι ΜΟΝΟ η σειρά Χ3000 θα είναι και 1080p και 100 ΗΖ!
Άρα η W3000 δεν θα έχει 100HZ ??? :BXVZCBXZ6:
