PS3 firmware update 1.80
Μιχάλης Κορ.
21,757
Βαρυμπόμπη
Ανακοινώθηκε ότι από αύριο 24-5-2007 θα υπάρχει νέα έκδοση firmware 1.80 που μεταξύ άλλων θα κάνει upscale sd dvd, upscale παιχνίδια των ps1 & ps2 στα 1080p αλλά και να δικτυώνεται με υπολογιστή για να προβάλει φωτογραφίες, βίντεο, μουσική κτλ κατευθείαν χωρίς την χρήση linux κτλ...
Sony ευχαριστούμε πολύ για την συνεχή κ ταχύτατη υποστήριξη !!! :grinning-smiley-043
"The Latest PLAYSTATION 3 Firmware Update Provides PlayStation, PlayStation 2 and DVD Upscaling Remote Play on PSP (PlayStation Portable) via the Internet and DLNA transfer of media content.
Sony Computer Entertainment Europe (SCEE) announced today availability of the latest version of the PLAYSTATION�3 (PS3™) firmware. Version 1.80 features upscaling of PlayStation� and PlayStation 2 games, and DVD movies up to full 1080p HD resolution when viewed on a compatible HD TV set.
The capability to upscale DVDs to HD quality is a feature normally only associated with top range DVD players, and its inclusion in the latest firmware upgrade now allows PS3 owners with an existing DVD collection to dramatically enhance the viewing pleasure of their DVD collection when viewed through a compatible HD TV set1. Not only can DVD movies be enhanced to full 1080p HD quality but so too will PlayStation 2 and PlayStation games be upscaled to provide much improved gaming pleasure.
In a comprehensive update to PS3’s already impressive capabilities, Version 1.80 also allows users to enjoy Remote Play on their PSP across the internet, allowing them to access their PS3 anywhere in the world where a broadband internet connection is available2.
Version 1.80 also allows users on a home network to seamlessly view and play rich media content such as images, music and video on their PS3, that is stored on their DLNA3 enabled devices such as PCs and laptops elsewhere in the house, reinforcing PS3’s credentials as a home entertainment hub that truly deserves pride of place in the Living Room.
A host of other enhancements include the ability to print photo images stored on PS3’s hard disk or inserted storage media to a selection of Epson printers.
PS3 owners will be able to upgrade their PS3 with the latest Version 1.80 firmware from 24th May 2007."
Πηγή : http://www.gameswank.com/content/view/100/1/
Press Release : http://www.scee.presscentre.com/Content/Detail.asp?ReleaseID=4372&NewsAreaID=2
NA ρωτησω κατι..αν βαλω αυτο το firm,θα χαθουν τα demo games που εχει μεσα?οταν εβαλα την 1.70 δεν με ενδιεφερε ,γιστι δεν ειχα τιποτα μεσα..τωρα ομως κατεβασα ολα τα demo!!!
:grinning-smiley-043ΜΙΧΑΛΗ σε ευχαριστω για αυτη την ενημερωση.Μολις γλυτωσα αρκετα ευρω μια και αυριο ημουν ετοιμος να παραγγειλω DVD που να κανει upscaling 1080p.
Να πω και ενα μπραβο στη SONY για τις γρηγορες αναβαθμισεις.
Να τους τα χωνουμε οταν φταινε, αλλα και οταν κανουν κατι καλο,να το λεμε.
@optostyle : Δεν θα έχεις κανένα πρόβλημα με το update. Όταν εγώ είχα την κονσόλα κ το 1.5 είχα κατεβάσει τα demos, πήγα σε 1.60 κ μετά σε 1.70 χωρίς κανένα πρόβλημα.
@Παπ.Σωτήρη : Μέχρι στιγμής η Sony έχει κάνει πάρα πολύ καλή δουλειά γιατί από την ημερομηνία διάθεσης στην Ευρώπη πριν 1-1.5 μήνα, έχει δώσει 3 updates firmware με πολύ 'ζουμερό' περιεχόμενο...!
Ουτε η Microsoft δεν κανει τοσα update μεσα σε τοσο συντομο χρονικο διαστημα....:flipout: :flipout: :flipout:
Στέλιο μην το γελάς ... Τουλάχιστον η SONY τα φτιάχνει γρήγορα , όχι σαν κάτι άλλους που όποτε θυμούνται δίνουν ψίχουλα και παίρνουν πίσω χοντρά ...
Ανακεφαλαίωση χαρακτηριστικών από το :
http://www.avsforum.com/avs-vb/showthread.php?p=10615524#post10615524
* Υποστηρίζει 720p στα Blu-ray
* Υποστηρίζει 1080p/24 κ μάλιστα με δυνατότητα on/off.
* DVD upscaler: default = Normal. Έχει επιλογές Double Scale & Full Screen. Αλλάζουν κ κατά την διάρκεια της ταινίας.(on the fly)
(Full stretches 4:3 DVDs. Normal keeps them at 4:3.)
Κάποιες επιλογές που θέλουν ψάξιμο τι κάνουν :
* RGB full range - I set this to Full. default = limited.
* Y/Pb/Cb Pr/Cr Super-White (HDMI) - off = default.
* Audio Settings: νέα επιλογή Bitmapping (SACD). Off και Type 1(default).
* Όταν βλέπουμε ένα dvd μπορούμε να επιλέξουμε το "Image Quality Adjustment" μέσω του οποίου μπορούμε :
1. Frame Noise Reduction (επιλογές "off", 1, 2, 3),
2. Block Noise Reduction (επιλογές "off", 1, 2, 3),
3. Upscale (επιλογές Normal, Double scale, Full)
4. και Super White.
Κάποια σχόλια δοκιμών από χρήστες :
* I have just completed the HQV tests on the PS3 on firmware 1.8. The good news is that the PS3 now passes ALL the tests on the DVD, cadence, interlacing, artifacting. The output is clearly superior over my Denon 3930CI DVD player. The PS3 extracts more detail from standard DVDs over anything else I have seen. There are other options, such as 1080P 24Hz, white enhancing. The unit will out 1080P24Hz and lock in on the Mits HC500 and JVC RS1 with no problems. i have not tested the white enhancing yet but I assume it fixed the crushed gray scale issues.
* A quick test with Wizard of Oz and Mad About You reveals that the update also correctly pillarboxes 4:3 DVD content on 16:9 displays.
Όλα τα λεφτά.... :grinning-smiley-043 :grinning-smiley-043
Για όποιον θέλει να κατεβάσει το firmware από τον υπολογιστή του, τότε πάει εδώ :
http://djp01.ps3.update.playstation...fd9887626f734b46b271aec58e827cb2/PS3UPDAT.PUP
είναι 110mb περίπου.
Μετά το γράφουμε σε ένα cd ή ένα memory stick σε συγκεκριμένο όμως φάκελο :
/PS3/UPDATE/
Πάμε στο ps3, επιλέγουμε system update αλλά εκεί του επιλέγουμε όχι μέσω ίντερνετ αλλά μέσω άλλου media. -bye-
To νέο update 1.80 το έκανα εγκατάσταση...
Τώρα το PES για PS2 τρέχει στα 720p είναι σαφώς βελτιωμένο αλλά μην φανταστείτε ότι είναι HD.
-bye-
το πέρασα κι εγω,μεγαλη διαφορα προς το καλύτερο στα dvd.
1080p/24 δεν μπόρεσα να δω αν και στο μενου εμφανίζεται σχετικό ερώτημα πλέον...
έχω κάπου 10 blu ray και κανένα δεν γράφει 24fps
πάντως η sony έδωσε καλούδια που στοιχίζουν, και της αξίζει ένα μπράβο...:SFGSFGSF:
