Nabilosat Enigma2 Black Hole - DM800 v0.7
leo06
14 October 2007
7,019
Πάτρα
Nabilosat Enigma2 Black Hole - DM800 v0.7 What is new in this version 0.7 ? Nabilosat Black Hole v0.7 is highly optimized to offer an HD skin with best performance, speed and reliability. EPG Loader Updated OpenTV EPG Loader by MaxZ4 NEW EPG SEARCH FEATUREs Open the TV channel selection list and use keys 1,2,3 and 4 to launch the new options KEY 1 will launch the EPG Search for titles KEY 2 will shortcut the single channel EPG. Move the cursor to select the channel and press 2 KEY 3 will shortcut Multi EPG. KEY 4 will list the last search keywords. Use it to repeat previous or favorite searches. NABILO E2 EPG - Enable/Disable Pop Up Window A new setting is added to the Nabilo E2 EPG. Set it to NO if you want to hide the EPG download Pop Up window NABILO INFO PANEL - HDD Temperature A new information is added to the panel. Press the Blue button, then the Yellow button and select HDD temperature to check how hot your hard disk is. NEW SKIN High resolution skin HD-ONE by Matrix10 NEW HD BOOT LOGOS High resolution bootlogos by MaximoII NEW WEB INTERFACE This new image includes the latest version of the Enigma2 Web Interface. Enigma2 CVS date 16 January 2009 2.6 experimental Drivers date 10 December 2008 Second Stage #70 Plugins Date 16 January 2009 Plugins will be available for download from the Addons Panel. Many thanks to our BIG brother franzjuve for packing them NOTE You can install this image to flash, without any further support. You can install this image to multiboot. In this case, you must have the Nabilosat Pure Flash 29DEC2008 installed to flash. This is necessary because the flash image must include the second stage #70 Nabilosat DM 800 Pure Flash dated 29 December 2008 is available here Main Function Keys Button 1xOK = Light Info Skin Button 2xOK = Extra Info Skin Button Blue = Nabilo Blue Panel Button Blue-Long-Push = Extensions Button Green = Nabilo Green Panel Button Green-Long-Push = Subservices Button Red = Start Record Button Yellow = Time Shift Addons Dedicated Addons Server Download and install additional packages from Nabilosat server Infobar/OSD Enigma2 Analogic Clock Channel Orbital Position Advanced Tuner Info: Sr Freq Pol Fec Signal SNR, BER Infobar Picons LCD/OLED Picons Advanced EMU information Nabilo Panels features 1) Blue Panel Setup OSD Settings Nabilosat E2 EPG Settings LCD Settings Fast Plugin Settings Inadyn Settings Swap File Settings Hard Disk Setup Nabilo Mount Wizard OpenVPN Panel Samba/Cifs Panel NFS Server Panel Telnet Panel FTP Panel Info CCcam Info Memory Info Available Space Processes Service Info Hard Disk Temp Enigma2 Settings About Save Select/Start/Restart EMU 2) Green Panel Shoutbox Fast Plugin Addons Addons Download Manager Manual Install Nab packages Manual Install IPK packages Addons Uninstall Panel Nabilosat Statistics Scripts Many thanks to the Beta Testers Team Black33, ^^Corrado^^, Maximo II, greg, Matrix10, Porto, Nabilo, Army, Piefav, franzjuve, Willow, fbrassin, Neri73, paribas, astemio, lorenzo64, frimmino, nixus, robyhummy, snakie, DeepDiver Credits E2 Sky Epg loader integration by MaxZ4. Matrix10 for the new HD One skin. ^^MaXiMo^^ for bootlogos. Many Thanks to lukkino (VDR-Italia) for opentv source code. This Images doesn't contain any keys nor softcams. Backups or other modified Images are not supported! WARNING. This image includes second stage #70. Therefore, if you install it to multiboot, it will not work with any previous image in flash. If you install it to multiboot, you must install the Nabilosat Pure Flash DM 800 dated 29 December 2008. ATTENZIONE. Questa immagine include il second stage #70. Quindi, se la installate in multiboot, assicuratevi di aver installato in flash la Nabilosat Pure Flash DM 800 del 29 Dicembre 2008. .
Eυχαριστουμε για την πληροφορηση φιλε leo06 αλλα ως συνηθως το site τους ειναι down για μενα τουλαχιστον που εχω forthnet..
σε μενα με tellas μια χαρα ειναι το site τωρα το ποτε θα καταφερω να κατεβασω το image δεν μπορω να σου πω γιατι εδω και μια ωρα εχει κατεβει μονο 1% ουτε dial up να ειχα tellas το μεγαλειο σου
Το κατεβασα απο αλλο σαιτ που ειμαι γραμμενος τελικα. Το εκανα εγκατασταση αφου εκανα εγκατασταση πρωτα το νεο Barry Allen 4.6.70.
Παραδοξος το σαιτ της Nabilo δουλεψε μεσω του ιματζ και κατεβασε και καποια συγκεκριμενα plugins που ηθελα και το psipsi cam το τελευταιο. Το software update βρηκε επισης κανα 2 updates και κατεβασε.
Εχω την εντυπωση οτι το νεο Barry Allen εχει κανει το bootαρισμα λιγο πιο γρηγορο και εαν δεν κανω λαθος ειναι η πρωτη φορα που μου μετεφερε ολα τα settings απο το Nabilosat Enigma2 Black Hole - DM800 v0.6 ατοφια στο νεο ιματζ, ακομα και τους δορυφορους/καναλια κ.τ.λ.
Οσο για το ιματζ, εχει διαφορετικο skin απο το 0.6 και γενικως μου δινει την εντυπωση οτι ειναι πιο γρηγορο. Θα το δουλεψω λιγο ακομα και θα επανελθω. Σημειωτεων εχω στην flash το τελευταιο Pure image της Nabilo και το ιματζ το εχω στο στικ.
Μόλις το κατέβασα χωρίς πρόβλημα απο το site του Nabilo..
Περισσότερα αργότερα..
Και επειδή τα χαρακτηριστικά του βγήκαν κάπως χύμα στο πρώτο μήνυμα τώρα ελπίζω με copy - paste να διαβάζονται πιο ξεκούραστα:
EPG Loader
NEW SKIN
NEW HD BOOT LOGOS
NEW WEB INTERFACE
Enigma2 CVS date
Drivers date
10 December 2008
Second Stage #70
Plugins Date
16 January 2009
NOTE
Main Function Keys
Addons
Infobar/OSD
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
1) Blue Panel
Setup
OSD Settings
LCD Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
CCcam Info
Memory Info
Available Space
Processes
Service Info
Hard Disk Temp
Enigma2 Settings
About
Save
2) Green Panel
Shoutbox
Fast Plugin
Addons
Τωρα θα τον ξαναστησω απο την αρχη και θα το περασω μεσα!!
Σκευτομουν να περασω και τιποτα anti-freeze alla fobame mhn pesv se tipota bombs και τον διαλυσω!!
EPG Loader
NEW SKIN
NEW HD BOOT LOGOS
NEW WEB INTERFACE
Enigma2 CVS date
Drivers date
10 December 2008
Second Stage #70
Plugins Date
16 January 2009
NOTE
Main Function Keys
Addons
Infobar/OSD
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
1) Blue Panel
Setup
OSD Settings
LCD Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount ******
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
CCcam Info
Memory Info
Available Space
Processes
Service Info
Hard Disk Temp
Enigma2 Settings
About
Save
2) Green Panel
Shoutbox
Fast Plugin
Addons
Scripts
Credits
WARNING.
Με Sky UK που το εχω δοκιμασει μου δουλευει μια χαρα. Παιρνει τα updates καθε βραδυ απο τον ραδιοφωνικο σταθμο hip-hop και εχω ετοιμο ολο το προγραμμα του μηνα..-bye-
Η ρυθμιση αφορα sky uk και sky it. Μπλε κουμπι Χ2 και πας epg η κατι τετοιο. Εκει εχει ρυθμισεις και για τα 2.
Το εκανα αλλα συμβαινει κατι περιεργο...
Δεν μπορει να βρει σημα σε κανενα HD καναλι (σε ολους τους δορυφορους)!!!
Βγαζει συνεχως Tuned failed !
Ολα τα Sd ta pianei kanonika... τι συμβαινει ?
κανε παλι scan ολους τους δορυφορους..χωρις να κανει clear
καποιος ειχε πει οτι η νοβα χρησιμοποιει το ιδιο ειδος epg με τα sky και θα μπορουσαμε καπως να εχουμε εβδομαδιαιο..ισχυει?
