Νέοι προβολείς BENQ 2012-2013
gzoun
8 March 2008
1,958
Αθήνα-Μενίδι
NEOI BENQ W750, W1070, W1080st, W1400
Νέους προβολείς περιμένουμε από την BENQ στις αρχές του φθινοπώρου.
Μερικά από τα νέα μοντέλα είναι τα ακόλουθα:
W750
W1070
W1080st
W1400
Περισσότερα χαρακτηριστικά με το που ανακοινωθούν τα επίσημα στοιχεία......
http://www.perfectimage.gr/2012/07/19/neoi-benq-w750-w1070-w1080st-w1400/
vas_papavas
21 December 2010
8,849
ΒenQ 1070​
Tεχνικά χαρακτηριστικά
Projection System DLP
Native Resolution 1080p (1920 x 1080)
Brightness* 2000 ANSI Lumen
Contrast Ratio 10000:1
Display Color 1.07 Billion Colors
Lens F=2.59-2.87, f=16.88-21.88mm
Aspect Ratio Native 16:9 (5 aspect ratio selectable)
Throw Ratio 1.15-1.5 (79"@2M)
Image Size (Diagonal) 40"-235"
Zoom Ratio 1.3:1
Lamp Type 240W
Lamp(Normal/Economic Mode/SmartEco Mode)* 3500/5000/6000 hours
Keystone Adjustment 1D, Vertical ± 20 degrees
Projection Offset Vertical 110%-130%±5%
Resolution Support up to WUXGA
Horizontal Frequency 15K-102KHz
Vertical Scan Rate 23-120Hz
Dimensions(W x H x D) 312 x 109 x 244 mm
HDTV Compatibility 480i, 480p, 576i, 567p, 720p, 1080i, 1080p
Video Compatibility NTSC, PAL, SECAM
Weight Net weight: 2.65 kg
Gross weight: 3.95 kg
Audible Noise 33/30 dBA (Normal/Economic mode)
Power Supply AC 100 to 240 V, 50 to 60 Hz
Power Consumption 353W/110V (typical), Standby < 0.5W
On-Screen Display Languages Arabic/Bulgarian/ Croatian/ Czech/ Danish/ Dutch/ English/ Finnish/ French/ German/ Greek/ Hindi/ Hungarian/ Italian/ Indonesian/ Japanese/ Korean/ Norwegian/ Polish/ Portuguese/ Romanian/ Russian/ Simplified Chinese/Spanish/ Swedish/ Turkish/ Thai/ Traditional Chinese (28 Languages)
Picture Modes Dynamic / Standard / Cinema / 3D / User 1 / User 2 / User 3
Accessories (Standard) Remote Control w/ Battery
Power Cord (by region)
User Manual CD
Quick Start Guide
Warranty Card (by region)
VGA (D-sub 15pin) Cable
Accessories (Optional) Spare Lamp Kit
Ceilling Mount
3D Glasses
Carry Bag
Interface Computer in (D-sub 15pin) x 1
HDMI x 2
Composite Video in (RCA) x 1
S-Video in (Mini DIN 4pin) x 1
Component Video in x 1
Audio in (Mini Jack) x 1
Audio L/R in (RCA) x 1
Audio out (Mini Jack) x 1
Speaker 10W x 1
USB (Type Mini B) x1 (for service)
RS232 (DB-9pin) x 1
DC 12V Trigger x 1
http://benq.eu/product/projector/w1070/
Κάδρο vs απόσταση
http://www.benq.com/microsite/projector/throwratiocalculator/
Κάποια πρώτα reviews (στα γαλλικά):
http://www.audiovideohd.fr/tests/344-Benq-W1070-0.html
http://www.cinetson.org/phpBB3/proj...ull-ready-899-euros-test-ligne-t36433-75.html
ME dc3, 3d, κάθετο lens shift (έστω και υποτυπώδες), short throw φακό (79@2μ), ιsf, ανοιχτό μενού και τιμή γύρω στα 900 ευρώ στην ευρώπη, φαίνεται πολύ ελκυστική περίπτωση και ήδη συζητιέται πολύ στο εξωτερικό. Αναμένουμε βέβαια να τον δούμε πρώτα στην πράξη όπως και τις μετρήσεις του Μανώλη Καστρουνή.
gzoun
8 March 2008
1,958
Αθήνα-Μενίδι
vas_papavas
21 December 2010
8,849
ΝΕΟΙ BENQ W1500, W770ST, SH910, MX520
W1500
1080P, FULL 3D, DC3, 1.6 x Zoom, Wireless FHD, ISF
Frame Interpolation, V Lens shift , New 3D,
2200 ANSI Lumen, HDMI*2, 10,000:1 CR, SmartEco, 0.5W
Eκτιμώμενη Τιμή : 1800Εuro
W770ST
720P, FULL 3D, DC3, SHORT TROW 0.72 T/R, 1.2X Zoom, New 3D,
2200 ANSI Lumen, 13,000:1 CR, HDMI*2, SmartEco,
Eκτιμώμενη Τιμή : 790Εuro
SH910
1080P, DC3, 1.5 X Zoom, LAN Display, HDMI
4000 ANSI Lumen, 3,000:1 CR
Eκτιμώμενη Τιμή : 2.000Εuro
MX520
XGA, DC3, 1.1X Zoom, HDMI, SmartEco, FULL 3D
3000 ANSI Lumen, 13,000:1 CR
Eκτιμώμενη Τιμή : 560Εuro
Πηγή:http://www.perfectimage.gr/2013/03/19/new-benq-w1500-w770st-sh910-mx520/
vas_papavas
21 December 2010
8,849
BenQ W1500 review
Characteristics (manufacturer's data):
DLP Dark Chip 3, 6-segment color wheel (X6)
Resolution: Full HD 1080p 1920 x 1080
Brightness: 2200 ANSI Lumens
Contrast: 10,000:1
Zoom: 1.50:1
Life of lamp: 3500 hours in normal mode and 5,000 hours in economy mode, 6000 hours in Eco Mode smart.
Image formats: 16:9 / 4:3 / Wide / Letter Box / Anamorph / real
Inputs: HDMI with HDCP x 2, Composite Video: RCA 1 x RCA, Component 1 x RCA x 3 S-Video: 1 x Mini DIN 4 pin, VG RGB: 1 x D-Sub 15 pin, USB: 1 x Mini Type B, Audio In: 1x 3.5mm Audio In: 2x L / R Cinch
Speaker: 1 x 10 W
Power Consumption: Max. 295 Watt, Standby <0.5 Watt
Suggested retail price: 1499 euros
Cinema Mode (color temperature (6133K gap of 4 gamma delta E 2.44)
After calibration and bypassing the ISF box or CCA, we arrive at results consistent with references and tolerable deviations. (Color temperature of 6573K with a gap of 1.1 deltaE, linear gamma to 2.27).
Contrast and brightness measured after calibration:
Bright color lamp off low 274 lux 716 lumens
Brilliant color off top 465 lux lamp 1216 lumens
Brilliant color on low 388 lux lamp 1014 lumens
Brilliant color lamp lumens above 570 lux 1490
Black level: 0.07 lux
Contrast: 3914:1
The dark chip 3 chip combined with optimization of the light path are responsible for these very good contrast values ​​and brightness and is also found in the image.
Πηγή:
http://translate.google.fr/translat...w.audiovideohd.fr/tests/357-BenQ-W1500-0.html
vas_papavas
21 December 2010
8,849
BenQ w750
Ποιος σας είπε ότι οι προβολείς με ανάλυση 720p(1280 x720) για οικιακή χρήση έχουν πεθάνει;
Μάλλον όλοι εμείς κάνουμε λάθος εκτίμηση δεδομένπου ότι ακόμη και σήμερα εταιρείες όπως η BENQ λανσάρει νέο προβολέα σε αυτήν την κατηγορία και μάλιστα με δυνατότητα 3D.
Για αυτούς που θέλουν να μπούν δειλά-δειλά στον χώρο της βιντεοπροβολής ο Benq W750 μπορεί να αποδεχθει μια καλή επιλογή και μάλιστα σε τιμή κοντά στα 600 ευρώ.
Τεχνικά χαρακτηριστικά
Native Resolution 720p (1280 x 720)
Brightness* 2500AL
Contrast Ratio 13000:1
Lens F=2.54-2.73, f=18.18-21.84mm
Throw Ratio 1.31-1.57 (60″@2M)
Image Size (Diagonal) 43″~300″
Zoom Ratio 1.2:1
Lamp Type 210W
Lamp(Normal/Economic Mode/SmartEco Mode)* 4000/5000/6500 hours
Keystone Adjustment 1D, Vertical +/- 40 degrees
Projection Offset 120% ±5%
Resolution Support Up to UXGA(1600 x 1200)
Horizontal Frequency 15K~102KHz
Vertical Scan Rate 23~120Hz
HDMI (v1.4a) x 2
Speaker 10Wx 1
USB (Type mini B) x1
RS232 (DB-9pin) x 1
IR Receiver x2
Dimensions(W x H x D) 324.7 x 113.8 x 241.5 mm
Video Compatibility NTSC, PAL, SECAM, SDTV
Weight 2.6 Kg (5.73 lbs)
Audible Noise 34/30 dBA (Normal/Economic mode)
Power Supply AC 100 to 240 V, 50/60 Hz
Power Consumption 275W (typical), Standby< 0.5W
Picture Modes Dynamic/Standard/Cinema/3D/User 1/User 2/User 3
Accessories (Standard) Remote Control w/ Battery (Full type x 1, RCX001W)
User Manual CD (24L)
Quick Start Guide (18L)
Accessories (Optional) Spare Lamp Kit P/N: 5J.J7K05.001
Ceilling Mount P/N: 5J.J2K01.001
3D Glasses P/N: 5J.J7K25.011
Carry Bag
Πηγή: http://www.perfectimage.gr/2013/04/21/benq-w750/
JIMBOAthens
4 February 2008
222
Έχουμε κάποια πληροφορία για την ημερομηνία κυκλοφορίας του W1500 στην Ελλάδα?
vadergr
17 August 2007
27,525
Μεταμορφωση
Πληρως αναξιοπιστο site.
Ασε που ουσιαστικα παίζει οπως ο 1070.
Η διαφορα τιμης ειναι νομιζω στο wifi και στον φακό ...
JIMBOAthens
4 February 2008
222
Αυτό είναι το θέμα. Αν έχει ίδιας ποιότητας μαύρο με τον W1070 και ίδιο 3D τα σχεδόν 1000 που τους χωρίζουν είναι κατά την προσωπική μου άποψη εκτός πραγματικότητας...
