Intel Sandy Bridge-E
Alexandros_Wallace
3 June 2007
4,189
Dystopia
Sandy Bridge-E CPU Feature Overview
  • Up to 6 cores and 12 threads
  • 32-KB instruction and 32-KB data L1 cache per core
  • 256-KB shared instruction/data L2 cache per core
  • Up to 15 MB L3 cache (up to 2.5 MB per core) shared among all cores
  • Up to 40 PCIe Gen 3 Lanes (2x16 & 1x8)
  • 4 lanes of DMI2/PCI Express 2.0 interface
  • 4 Channels DDR3-1600 (1 DIMM per Channel)
  • Intel Turbo Boost Technology 2.0 (thermal control is the only limiter)
  • 130W TDP
  • LGA2011 Socket
Sandy Bridge-E comes in 3 SKUs :
  • Sandy Bridge Extreme Edition : 6 cores / 12 threads, 3.3GHz clock, 15MB L3 cache (2.5MB per core), Max. OC
  • Sandy Bridge E : 6 cores / 12 threads, 3.2GHz clock, 12MB L3 cache (2MB per core), Max. OC
  • Sandy Bridge E : 4 cores / 8 threads, 3.6GHz clock, 10MB L3 cache (2.5MB per core), Limited OC
Intel X79 Express Chipset (Patsburg-HEDT) Overview
  • 10 SATA 6Gbps ports with SAS capability
  • 4 SATA 3Gps ports
  • PCIe 3.0 x4 uplink for dedicated storage bandwidth
  • 8 PCIe 2.0 lanes
  • 14 USB 2.0 ports
  • Integrated Gigabit Ethernet MAC (Lewisville PHY)
  • Intel Rapid Storage Technology enterprise 3.0
    • SAS RAID support (0/1/10)
    • SAS Expander support
    • SATA RAID support (0/1/10/5)
    • Write Journaling
    • Open Source Linux support
  • 100MHz BCLK
  • Supports processor, memory and chipset overclocking
  • Supports Intel Extreme Tuning Utility 3.0 (XTU)
  • 8-layer PCB, 2oz copper recommended
περι τιμών...
Intel's Sandy Bridge-E priced, don't expect any surprises
When it comes to pricing, Intel is a very predictable company and although we're not quite sure why the company is sticking to the exact same prices over and over again, it's just how it is. One of our very reliable sources have come through with the pricing for Intel's upcoming Sandy Bridge-E processor and although there were whispers of a price point over US$1,000, well, let's just say that there aren't any big surprises in store.
Read more: http://vr-zone.com/articles/intel-s...expect-any-surprises/13298.html#ixzz1dmQ5Jbab
Those of you buying today only have two options: the Core i7-3960X and the Core i7-3930K. Both have six fully unlocked cores, but the 3960X gives you a 15MB L3 cache vs. 12MB with the 3930K. You pay handsomely for that extra 3MB of L3. The 3960X goes for $990 in 1K unit quantities, while the 3930K sells for $555.
The 3960X has the same 3.9GHz max turbo frequency as the Core i7 2700K, that's with 1 - 2 cores active. With 5 - 6 cores active the max turbo drops to a respectable 3.6GHz. Unlike the old days of many vs. few core CPUs, there are no tradeoffs for performance when you buy a SNB-E. Thanks to power gating and turbo, you get pretty much the fastest possible clock speeds regardless of workload.
Early next year we'll see a Core i7 3820, priced around $300, with only 4 cores and a 10MB L3. The 3820 will only be partially unlocked (max OC multiplier = 4 bins above max turbo).
και άλλη μια μητρική από την asus με X79
ASUS ROG X79 Motherboard: Rampage IV Extreme Features Talk About
Portioli μπράβο για τις πληροφορίες που παραθέτεις.
Κατά τη γνώμη μου είναι καλή λύση για εργαλεία-δουλειάς workstations.
Μπορεί να είναι μικρή η αγορά για δυνατά workstations, αλλά υπάρχουν δουλειές στις οποίες ένα σοβαρό workstation γίνεται απόσβεση. Φίλοι που ασχολούνται με 3d το σκέφτονται και ξεκινάνε παραγγελίες.
Φυσικά η πλατφόρμα βγαίνει τσουχτερή… αλλά είπαμε εάν είναι για εργαλείο δουλειάς, όλα δικαιολογούνται.
Χωρίς native υποστήριξη σε usb3... τι σκέφτεται αυτή η intel...
2500k το απόλυτο vfm αυτή την στιγμή...οι ivy bridge αναμένονται με ενδιαφέρον!!
τι σε πείραξε?
αυτό δεν γίνεται εδω και πόσα χρόνια (από τους core2duo)
η intel βγάζει λουκούμια για να αγοράζουμε τσάμπα AMD
Απάντηση: Re: Intel Sandy Bridge-E
Και μόλις απογοητεύτηκα...
Χωρίς ανταγωνισμό η intel κάνει ότι θέλει...
Ε? γιατί το λες αυτό? Οι επιδόσεις σούπερ, το efficiency από άλλο πλανήτη, και από ότι λένε βελτίωση και στις iGPU... εκεί που πάσχουν παραδοσιακά οι Ιντελ δλδ.
Στα συν επίσης ότι δοκιμάστηκαν κανονικά σε Ζ68 Μ/Β... Α, και ακόμα δεν έχουν παρουσιαστεί οι φτηνοί core i3...
Πολύ μικρή η διαφορά τον επιδόσεων... είχα την εντύπωση ότι αναμέναμε πολύ καλύτερα αποτελέσματα... Προσπαθώ να βρω έναν λόγο να τους προτιμήσω σε ένα σύστημα έναντι των 2500κ/2600κ... μόνο κάποιος που θα θέλει να στήσει ένα αθόρυβο σύστημα...
Εχω την εντύπωση ότι ήδη από τον 2500 καλύπτεται το 99% των χρηστών από θέμα επιδόσεων στο κομμάτι του επεξεργαστή, κάτι που όμως δεν συμβαίνει με τις ενσωματωμένες HD graphics, ούτε καν με την HD3000...
Από την άλλη πάλι, αυτά -αν κατάλαβα καλά- είναι πρώιμα samples, οπότε ακόμα είναι νωρίς να κριθούν... Αλλά και 5-10% παραπάνω ισχύ να έχουν, συνεχίζω να πιστεύω ότι είναι υπερ-υπεραρκετοί... Ειδικά όταν μιλάμε για καταναλώσεις με μέγιστο τα 77W!!!
Αυτό το HD2500 πρέπει να είναι το HD2000 με DX11 drivers αν έχω καταλάβει καλά…
H intel για άλλη μια φορά δεν ικανοποιεί… το ότι 99% των χρηστών δε φαίνεται να ασχολούνται είναι αλλού παπά ευαγγέλιο, καθώς το ίδιο ποσοστό πιθανότατα δε ξέρει καν τι είναι η κάρτα γραφικών, εάν ήξερε και είχε επιλογή θα έβαζε άλλη…
Πάντως και εγώ είμαι στο 99,999 (πόσα εννιάρια? :D ) που θα πρέπει να συμβουλεύεται πινακάκια της Intel για να καταλάβω εάν έχει ο επεξεργαστής vt-d ή ΗΤ ή τι έχει και τι δεν έχει γενικά.
Και σε τι τιμή θα τους βάλουν ώστε να τους προτιμήσει κάποιος από τους sandy? Αυτό είναι το ζήτημα. και ειδικά όταν οι περισσότεροι χρήστες είναι υπερκαλυμμένοι με τους sandy? Προσπαθώ να βρω κάποιον λόγο:
1ον)κάποιος που έχει sandy θα πάει σε ivy
2ον)κάποιος που θέλει να φτιάξει νέο μηχάνημα να προτιμήσει τους ivy από τους sandy...
εκτός από εξειδικευμένες περιπτώσεις...
Να τα μας....
Πριν από λίγο "έσκασε" πραγματικά μια ατομική βόμβα στον διεθνή ηλεκτρονικό τύπο: Η AMD αποφάσισε να σταματήσει να επικεντρώνει το ενδιαφέρον της στους επεξεργαστές για PC. Αντιθέτως, από 'δω και στο εξής θα κινείται περισσότερο στον τομέα των mobile CPUs. Οι καταστροφικές επιδόσεις των Bulldozer και τα λάθη του marketing τμήματος, που πριν από περίπου ένα μήνα οδήγησαν σε μαζικές απολύσεις του 10% του προσωπικού (60% από αυτό ήταν άτομα του marketing), πρέπει να "ταρακούνησαν" αρκετά την διοίκηση της εταιρείας, κάνοντάς την να καταλάβει ότι ίσως τα PC δεν είναι η καλύτερη επιλογή πλέον. Ο κόσμος περίμενε πολλά από τους καινούριους οχταπύρηνους επεξεργαστές και εν τέλει, έγινε μάρτυρας επιδόσεων χειρότερων των Thuban. Εξού και η απόφασή της να ασχοληθεί πιο σοβαρά με το mobile κομμάτι - ίσως να παραμετροποιήσει κατάλληλα την επιτυχημένη πλατφόρμα Fusion για να προκύψουν Fusion tablet/smartphone chips.
"Βρισκόμαστε σε σημείο καμπής", δήλωσε ο Mike Silverman, εκπρόσωπος τύπου της AMD. "Πρέπει όλοι να ξεχάσουμε τη νοοτροπία AMD vs Intel και να αλλάξουμε σελίδα", συνέχισε. Τα παραπάνω μοιάζουν απολύτως λογικά αν αναλογιστείτε ότι η AMD έμεινε για παραπάνω από 6 μήνες χωρίς πραγματικό CEO, έπρεπε λοιπόν να κάνει κάτι και μάλιστα άμεσα!
Η εταιρεία έχει ένα καινούριο ηγέτη τώρα. Βλέποντας την κατάστασή της πήρε δραστικά μέτρα που περιλαμβάνουν νέες κατευθύνσεις, όπως οι πρώτες AMD branded μνήμες RAM στις οποίες αναφερθήκαμε χθες.
Πηγές: http://www.hwbox.gr/...bile-agora.html
http://news.softpedia.com/news/AMD-Not-Competing-With-Intel-Anymore-Goes-Mobile-237103.shtml
http://www.insomnia.gr/topic/428136-amd-vs-intel-is-over-η-amd-στρέφεται-στην-mobile-αγορά/
τι και πως βρε παιδιά δεν σας ικανοποιεί η Ιντελ αυτή την στιγμή?
Εκτός από τις τιμές που στα high end κομμάτια της είναι απλησίαστη, αυτή την στιγμή είναι μπροστά σε όλα όσα μπορώ να σκεφτώ: performance/watt, performance/core, performance/clock, και ότι άλλο υπάρχει... Μόνο στα πολύ φτηνά cpu υπήρχε ανταγωνισμός, αλλά και αυτός έπαψε μετά την έλευση των φτηνών SB pentium / celeron...
Και ξαναλέω, ναι οι iGPU της είναι πολύ πίσω, αλλά αυτό δεν έχει να κάνει με τα cpu της...
και όλα αυτά τα λέει κάποιος που περίμενε να βγουν οι bulldozer μπας και αλλάξει πλατφόρμα, αλλά τελικά... τσάμπα η αναμονή.
edit: και κάτι ακόμα. Αφού δεν μπορεί πια να ανταγωνιστεί η amd την Ιντελ στα cpus στο υψηλό κομμάτι που οι επιδόσεις είναι το κύριο θέμα, μου φαίνεται λογικό να επικεντρωθεί εκεί που τα πάει καλύτερα, κοινώς στα fusion (και στην mobile αγορά) και φυσικά στις κάρτες γραφικών (πρώην ΑΤΙ).
βρε εσύ, μια χαρά με ικανοποιεί η intel, απλά προσπαθώ να καταλάβω την πολιτική της την συγκεκριμένη στιγμή, που πάει να πλασάρει ένα καινούριο προϊόν το οποίο μάλλον δεν έχει θέση στην αγορά...
Σταδιακά θα καταργηθεί η παλιότερη γενιά, και θα αντικατασταθεί από τη νέα.
