ONKYO ES-FC300 / ES-HF300 On-Ear Headphones
Gojakla
20 May 2009
5,856
ES-FC300
Built to deliver maximum fidelity at a realistic price, these stylish aluminum-encased headphones feature 40 mm (1 9/16˝) titanium drivers backed by sub-chambers to optimize bass response. Onkyo’s technical team spent countless hours tuning the drivers to deliver uncommonly clear, open, and natural sound from compressed or lossless formats. Premium audio doesn’t come at the expense of portability. Folding earcups, detachable connectors, and exceptionally tough construction make the ES-FC300s ideal for the daily commute. And you won’t spend half the journey sorting out a mess of cable: our flat elastomer design resists knots and tangles. An adjustable padded headband and leatherette earpads make extended listening sessions comfortable. Which is great, because with this level of audio performance, you’ll be finding any excuse to put them on.
Features
  • New 40 mm Wide-Range Titanium Drivers for Clearer Sound
  • Sub-chambers for Deep, Well-Defined Bass
  • Tough Aluminum Driver Housing and Hanger Arms
  • Low Noise, Tangle-Free Flat Elastomer Cable
  • Gold-Plated MMCX and Mini-Stereo Connectors
  • Easily Swapped or Upgraded Detachable Cable Design (Additional Cables Sold Separately)
  • L-Shaped Reinforced Stereo Plug
  • Folding Design for Portability
  • Adjustable Padded Headband
  • Comfortable and Stylish Leatherette Earpads
  • Compatible with Most Media Players
ES-HF300
Your passion for music is reflected in the aluminum driver housing, its shape referencing the volume control on our iconic audio components. The single-arm design creates a clean, elegant profile accentuated with brushed and burnished aluminum. Soft leatherette earpads and headband make for comfortable listening, but that’s just the beginning: two 40 mm (1 9/16˝) titanium drivers, sub-chambers for optimized bass, and rigid construction combine to present a wonderfully clear stereo image. These headphones handle everything from Mendelssohn to metal, with deep-reaching bass and a detailed mid-range—testament to the long hours spent tuning the drivers to perfection. Adding further value is the audiophile-grade copper cable, which provides almost perfect conductivity for superior sound quality. Protected by transparent elastomer to insulate against touch noise, the one-piece cable has gold-plated connections and is the perfect length for travel. Details such as the flat-folding design and detachable cable make it easier to enjoy component-quality audio everywhere you go.
Features
• Sub-Chambers for Deep, Well-Defined Bass
• 6N Oxygen-Free Copper Cable Protects Signal for Pure Sound
• Detachable Cable for Easy Replacement
• Tough Elastomer Cable Sheath Resists Tangling and Reduces Touch Noise
Επίσημες σελίδες: ES-FC300 & ES-HF300
Review στο Inner Fidelity από τον Tyll Hertsens: ΕΔΩ
Μετρήσεις του Inner Fidelity:
Συμπερασματικά, ο Tyll μιλάει για ένα ζεύγος ακουστικών με εξαιρετική απόδοση... τέτοια που κοντράρουν μεγαλύτερης αξίας, καταξιωμένα, ακουστικά.
:ernaehrung004:
όση καλωσύνη να έχουν, πατσουλημένα αυτιά φτιάχνουν.
και καλός ήχος με supra aural δεν υπάρχει.
και μεταξύ μας....έμαθε και η onkyo ότι κάποιοι βγάζουν λεφτά από ακουστικά......:twoguns:
... καλός ήχος με supra aural δεν υπάρχει.
Και της Focal έτσι δεν είναι?
Αν ναι, όταν τα δοκίμασα δεν μου άρεσαν καθόλου από εφαρμογή και άνεση.
Για ποιότητα, τα Focal τουλάχιστον, ήταν οκ. Εγω προσωπικά δεν εντυπωσιάστηκα αλλά άλλοι (πχ ο Sonus) τα εκτιμούν ιδιαίτερα...
Οπότε, μήπως να δίναμε μια ευκαιρία και στα Onkyo?
Βασικα,εγω το ψαχνω αρκετα προς την κατευθυνση ενος καλου και σοβαρου κλειστου τυπου,φορητο μοντελο (φορητο με την εννοια ευκολοδηγητο περισσοτερο,με μια τυπικα ανθρωπινη εμφανιση μπας και το βαλω καποια στιγμη σε καποιο δημοσιο χωρο πχ),αν και κοιτω για circumaural σχεδιαση (over ear).Κοιτω ομως και λιγο τα on ear μοντελα.
Και φυσικα οχι πολυ ακριβα.
Με δυο λεξεις: Εχω χασει τη μπαλα.Ειναι παρα πολλα τα μοντελα.
Αν δε δοκιμασεις δε μπορεις να ξερεις.Ουτε σαν ηχος,ουτε σαν ανεση.
Σε γενικες γραμμες τα Over ear ειναι πιο ανετα.Εξαρταται ομως και απο τη σχεδιαση και απο τον καθε ανθρωπο.Δεν επεται οτι ολα τα On ear ειναι αβολα και για ολους το ιδιο.
Επισης μπορει η οποιαδηποτε εταιρια να βγαλει ακουστικα με σωστο ηχο,γιατι οχι?
έζησα για αρκετό καιρό με τα Κ140.
Όμορφος ήχος, αλλά μόνο για 10-15 λεπτά.
Και όχι για καλοκαίρι.
Και προφανώς δεν προσφέρουν καμμία απομόνωση ώστε να είσαι σίγουρος τι ακούς. Αλλιώς κάθονται στο δικό σου αυτί και αλλιώς στου αλλου.
Απορώ πάντως.
Το πιό βολικό, εύχρηστο και σίγουρο ακουστικό είναι το Κ240.
Και πείτε με κολλημένο.
