Δέκτες Vu+: Images / Drivers
sat gr
22 March 2011
78
Aυτό το εργαλείο είναι για να μπορέσετε να πάρετε ένα αντίγραφο ασφαλείας (backup) ολόκληρο το image από τον δέκτη σας
δουλεύει σχεδόν σε όλους τους Enigma2 δέκτες και όχι μόνο σε Pli
BackupSuite 11.0
FOR OPENPLI 3.0 / OPEN EMBEDDED 2.0 ONLY !
Changelog
Changed in version 11.0 compared to 10.9
- Added extended loging in /tmp in the file BackupSuite.log. This should enable me to give better support in case of problems, pinpointing the process which is causing errors should be made easier.
Version 9.8 OpenPLi 2.1
Changelog
Changed in version 9.8
Very minor code changes and added support for upper-and lowercase recognition of the (part of the) file name for the direct-to-USB back-up. Sun backup drive is now so a valid name, upper and lower case can be mixed.
This version is not online in the feed, this will probably be the very last version intended voor OpenPLi 02.01
There is already a version 10.1 in the feed for OpenPLi 3.0 (and 3.0 OpenPLi ONLY). If you have 9.7 installed and it is working well there is no need to update to 9.8
BackupSuite 11.0 for o.e. 2.0
BackupSuite 9.8 for o.e. 1.6
Black Hole 2.0.0 OE 2
The Black Hole Image 2.0.0 is completely new and based on the new Vu+ OE. We used the name OE 2.0 only to maintain a tradition started by DMM, but in reality OE 2.0 does not mean anything. We could call it OE 3.0 or 4.0. This is because the new version of OE doesn't have a numbering system, as it is updated continuously and is dynamically linked to the new Vu+ OE. The Black Hole image 2.0.0 is the result of a long process of coding and testing. During the transition to Version 2.0.0 the Black Hole Team has created a dedicated server to support the image that is now live and available to users.
  • Black Hole official feeds (for updating the image on-line)
  • Black Hole Addons server (a new server with new addons plugins for OE 2.0)
  • Black Hole feeds plugins (official E2 compiled plugins for the Black Hole and accompanied by a detailed description)
  • Black Hole feeds settings (settings packages)
As for the details of the updates due to the transition to the new OE version the entire subsystem of the image has been updated and this means that the image has a new engine.
What is new ?
In reality there are too many changes and updates to list, but as most are not "visible" to "an end user" we will just list the important ones that you can see and will use.
  • Online Black Hole Update feature.
Green panel> Addons> Online Black Hole image update.
The Black Hole image is now fully upgradeable online. With this function, you can now keep the Black Hole image installed up to date. For example, the release of new drivers from Vu+ and also in the daily work that is done by the team in their Vu+ Git. The Black Hole team will follow the daily development work of Vu+, and will provide a regular update of the image.
  • Complete translation of the Black Hole Image.
Starting with version 2.0.0 the Black Hole image is fully translatable. The image already contains a complete translation in Italian. All language files available will be posted on the board to be fully translated by any users who want to make their contribution.
  • Restructuring main menu.
The main menu of the Black Hole has been restructured and enriched with new items, to offer a more convenient and easier access to all features of the image.
  • Addons server
The addons server has been renovated. As you know plugins for the new OE 2.0 are NOT compatible with the previous OE 1.6 versions, the new OE uses an updated version of Python> 2.7. All plugins on the addons server have been removed and / or replaced with new plugins that are compatible with the new version.
  • Feeds Plugins.
Green panel> Addons> Addons Download Manager> Black Hole Feeds Plugins.
In addition to the plugins on the addons server, now we have available a separate section for about 80 classic Enigma2 plugins which in the past often did not work due to incompatibility with version or architecture (e.g. BitrateViewer etc. ..). All of these plugins have now been updated to work with the Black Hole images and are available in the feeds panel.
The Black Hole team has also added a little description for each plugin to help you understand what they do and where they are located.
  • Online Feeds Settings Update.
Green panel> Addons> Online Feeds Settings update.
This new feature lets you keep your settings up to date if you choose one of the packages in the panel. The Black Hole server actually searches the servers automatically checking for updates of settings and will automatically package them and make them available in the panel as they become available. When the user enters the panel, The Black Hole image will automatically check the version of installed settings and proceed to the update.
  • Option to disable EIT for EPG and events.
Main menu -> Epg Panel -> Global Settings.
The EIT (Event Information Table) is a form of immediate epg which usually covers only two events (now and next), which usually is very capable and functional. However, this form of epg also tends to overwrite the epg that is in the cache, although it is often more accurate and complete.
But for those who are used to downloading a full epg package with CrossEPG or one of the other methods it can be very useful to disable the EIT so that the epg is not overwritten.
  • Automatic audio language selection
Main menu -> Black Hole Apps -> Auto language selection setting
This feature was originally implemented by the Pli team.
The function allows you to set a list of four preferred languages that will be automatically selected when you switch to channels with multiple audio tracks.
This is very useful when zapping channels with foreign languages that also broadcast the original soundtrack. In this case it will automatically select the preferred language. The list is in order of importance so if your first language choice isn't an option it will switch to your second or third choice.
You also have the option to give preference to Ac3 soundtracks if they are available.
If you set "Prefer audio stream stored by service" to "No" when you visit a channel and you select a different language then by default the software will remember that preference, however with Autolanguage when you next zap back to that channel it will automatically select the language of your choice set above.
PLEASE NOTE:
This image is not compatible with previous skin versions.
This image is not compatible with previous OE 1.6 plugins.
This image is not compatable with any previous Personal Backups you have made.
YOU MUST install this as a fresh image, restoring from a previous backup will corrupt the image and make it very unstable. You also will need to check for and remove any vuplus folders found on your hdd or usb devices before you install this image.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
The image MUST be installed in flash.
Black Hole does not support images not installed in flash.​
This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.​
Please note that of all images Black Hole now has the best epg system:
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Community members can then download it from our servers.
This feature provides other benefits such as:
Increase download speed of EPG
Download EPG from any channel
Schedule the download of EPG decoder even during standby
Users can customize the providers using Add / Remove function​
Main functions of the buttons on the remote​
OK button = Skin with simple information
OK button x 2 = Extra Info Skin
Blue button = Black Hole Blue Panel
Blue button and then Red button = Black Hole Epg Panel
Blue button and then Yellow button = System Monitor Panel
Blue button long press = Extensions
Yellow button = Audio menu
Green button = Black Hole Green Panel
Green button long press = Subservices
Green button and then Red button = Fast Plugin Setup
Green button x 2 = Fast Plugin
Button Red short press= access HbbTv functions
Button Red long press= Red Panel (Parallel Universes Teleportation)​
Addons​
Green button and then Yellow button takes you to:-
Dedicated server for BlackHole addons
Download and install additional packages from the Black Hole server​
Infobar / OSD​
Analog Clock Gui
Channel orbital location​
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar picons​
Characteristics of BlackHole Panels
Blue Panel
Extra Settings
Black Hole Speed Up
Black Hole Cron Manager (Manage schedules)
OSD Settings (OSD configuration)
Devices Manager
Usb Format Wizard
Kernel Modules Manager(Kernel module operator)
Inadyn Settings (Configure Inadyn)
Swap File Settings (Configure File Swap)
Hard Disk Settings (Configure Hard Drive)
OpenVPN Panel ( OpenVPN Panel)
Samba / CIFS Panel ( Samba Panel)
NFS Server Panel ( NFS server Panel)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
1 - Gui Setting (Gui configurations)
2 - Service Information (information system)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)​
EPG Panel
Global settings (global settings EPG)
Setting Provider (ISP settings)​
Green Panel​
Fast Plugin Setup (Configure quick access to your favourite plugin)​
Fast Plugin (Access your favourite plugin)​
Addons (added)
Addons Download Manager (Manager for package downloading)
Manual Install BH packges (Manual installation of Black Hole packages)
Manual Install IPK packages (Manual installation of IPK packages)
Addons Uninstall Panel (Uninstalled packages)
Black Hole Statistics (See connections, top downloads and more)
Red Panel
BH Parallel Universe Teleportation
Black Hole
Avalon
Chaos
Ghost​
Credits
Thanks to Pedro_Newbie for Backup script
Thanks to the group of Beta Testers.
Thanks to Rytec for providing us with the server with all epg.dat files.
Thanks to MaxZ4 for Integrated EPG loader.
Thanks to Skaman for Cross EPG
Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.
Thanks to Reinh@rd for the file satellites.xml.
DISCLAIMER​
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.​
THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.​
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
LICENSE (TERM OF USE)​
THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.​
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
DOWNLOAD
BH Cams 2.0.0 OE 2 in Trrplugin to test
We adapted all cams to new structure OE 2.0.0
Total 155 Files Test and report please
Neues VTi "Vu+ Team Image" - v. 5.1.0 - 16.02.2013
Vu+ Duo
Vu+ Solo
Vu+ Uno
Vu+ Ultimo
Vu+ Solo²
Vom VTi Team
VTi Panel (Blaue Taste)
Mehrsprachig:
Englisch, Deutsch, Italienisch, Niederländisch, Türkisch, Dänisch, Polnisch, Russisch, Ukrainisch, Tschechisch, Arabisch, Französisch, Schwedisch, Portugiesisch (Portugal), Griechisch, Bulgarisch, Ungarisch
Eigene Bootlogo's und neues Radiomode Logo.
kurzer Druck auf die Blaue Taste öffnet direkt das VTi Panel, ein langer Druck hingegen das Pluginmenü
Cronjobs werden vollständig unterstützt
Optimerungen des Kernels und Systems
Zahlreiche Optimierungen im Bereich Netzwerk u.a. für das Netzwerkbrowserplugin (verbesserte Zugriffe auf Freigaben)
Untersützung von Windows 7/Windows 8 beim Samba (CIFS)-Server
Swapdatei auch auf /media/usb
IPK Installation von Paketen unter /media/usb oder /tmp
Unterstützung von USB-Kartenlesern mit FTDI Chipsatz (Smargos,Easymouse2 etc.)
Gestartetes Softcam wird in der Infobar angezeigt
Erweiterte Sicherungs- und Wiederherstellungsmöglichkeiten
Wiederherstellung von Plugins, Bouquets, Einstellungen, etc. schon während der Installation möglich
Deinstallation nicht gewünschter Pakete schon während der Installation möglich (VTi Zero)
New VTi "Vu+ Team Image" - v. 5.1.0 - 16.02.2013
From VTi Team
VTi Panel (Blue Button)
Supported languages:
English, German, Italian, Dutch, Turkish, Danish, Polish, Russian, Ukrainian, Czech, Arabic, French, Swedish, Portuguese (Portugal), Greek, Bulgarian, Hungarian
VTi Bootlogos and new Radiomode Logo.
short press on blue button opens VTi Panel, long press opens Pluginmenu
Cronjobs fully supported
Kernel and system enhancements
Many enhancements in network and networkbrowserplugin
Support for Windows 7/Windows 8 Samba (CIFS-Server)
Swapfile at /media/usb
IPK-Installer search at /media/usb and /tmp
Support for FTDI chipset cardreader like smargo and easymouse2
Running Softcam shown in the Infobar
Enhanced backup and restore tools
Restore plugins, bouquets, settings, etc. during the installation
Remove preinstalled packages already during the installation (VTi Zero)
DOWNLOAD
Black Hole Vu+ v.2.0.0 rev. A
Update Black Hole 2.0.0 to rev. A
This update will fix the bug of green screen on system info exit.
Please upgrade Black Hole image.
Main Menu -> Addons -> Online Black Hole image update
Available: On line Update Black Hole 2.0.0 rev. B
Fixed:
Timezone
Factory reset
Autoresolution
Please update
Power of Dreams HD+ 3.0
26/01/2013
What you should know:
- Now also available for SOLO2
- There is little or no difference to the end user, most of the changes being located in the non-visible
- Epg for the sandbox, take the extension enigma2-plugin-extensions-sbx-crossepg source (which also automatically installs crossepg)
- The smartpicons are no longer installed by default, because a new breed of fact are smartpicons appearance (the 2d), which go very well with the PLi skin as HD, so you can choose the ones that suit you
Update:
- It is not possible to move from 2.1 to 3.0 without reflashing
- If you have a HDD that you save your configuration 2.1, the installer automatically retrieves the 3.0
χθες έγινε η νεότερη Online αναβάθμιση​
New Power Of Dream Image 3.0 for VU+ Based on PLI
Online Update 18/02/2013
vusolo2:
20130207 changelog:
- Support clipping
- Clean up videomode_choices
- Enhance PQ (SOLO2)
- Improve transcoding (SOLO2)
- Fix recording problem (SOLO2)
Online Update 27/01/2013
- Adding a 3rd smartpicons pack (black, 3d), thank you to the forum Doume Weblog
- Added usb drivers TNT stick on decorations that had been forgotten
- Update routine enigma
Second Online Update 27/01/2013
20130111
- Fix CI problem in dual tuner(ultimo)
- Support bypass edid
- Improve graphics2D
- Support hardware audio PCM codec(will be used in the upcoming new OE)
- Fix EOS detection in media playback
20130125
- Improve vtuner performance.
- Fix USB DVB-S/S2 vtuner lock failure problem.
- New skins initially designed for dreambox
Online Update 28/01/2013
- Fix (at least I think) the telco concerns on some menus and SOLO2 ultimo
- Add in DLC plugins: Cooltv, and Mytube backupsuite
Dear our valuable customers,
We are very happy to welcome you to The Vu+ Plugin Awards 2013 for the first time. The Vu+ Plugin Awards promote and reward excellence by recognizing innovative plugin developers for Vu+ models.
Vu+ Plugin Awards are awarded in series of the following categories.
1. System
2. Connectivity
3. UI
4. Multimedia (Recording)
5. Other
This award is opened to anyone who has deep interests in Vu+ as well as those who would like to take part in making Vu+ in a whole different level with the implementation of winning plugins in Vu+ products. Please be advised that there will be supplementary contract between the winners and Vu+ for the transfer of the rights on plugins.
Up to EUR50.000 will be awarded to the top plugin developers. The winners will be announced through Vu+ official website on 27th of May and will be invited to the The Vu+ Plugin Awards ceremony that takes place on the 5th of June at Vu+ booth at ANGA CABLE 2013.
1st winner - EUR10.000
2nd winners (5 participants) - EUR5.000 X 5
3rd winners (15 participants) - EUR1.000 X 15
Please submit your plugin with the detailed documentation to [email protected]
The deadline for submission is 12 May 2013 (date of sending). Entries must be submitted in English only.
Διόρθωση προβλήματος Timezone στο νέο BlackHole 2.0
Για να λυθεί το πρόβλημα της εσφαλμένης ένδειξης ώρας (λάθος χρονική χώνη) ακολουθήστε τα παρακάτω βήματα:
1. Συνδεθείτε με Telnet στο δέκτη
2. Εκτελέστε κατά σειρά τις εντολές
opkg update
opkg upgrade (θα εμφανιστεί μία σειρά σφαλμάτων)
opkg remove tzdata --force-depends
opkg upgrade (αυτή τη φορά θα εκτελεστεί κανονικά)
Ένα νέο opkg upgrade θα εκτελεστεί χωρίς να αναβαθμιστεί τίποτα, πράγμα που σημαίνει ότι όλη η προηγούμενη αναβάθμιση έχει εκτελεστεί επιτυχώς.
3. Κάντε επανεκκίνηση του δέκτη και πλέον η ώρα πρέπει να εμφανίζεται σωστά σύμφωνα με την επιλογή της χρονικής ζώνης
Η παραπάνω διαδικασία προέρχεται από το φόρουμ της Blackhole Team...
Black Hole 2.0.1 OE 2
What is new ?
New drivers (Solo2)
Change feed system with full paths for all machines
Update Videomode system plugin
Update en translation
Black Hole Speed: fully remove the disabled plugins from the system to increase speed and free flash space
fix timezones
fix bug in system info panel
fix bug in device panel
fix bug in image update
fix bug in autoswap
PLEASE NOTE:
YOU MUST install this image in FLASH.
You CANNOT use online update to upgrade image from 2.0.0 to 2.0.1.
logonewblackhole-jpg.10435
2-jpg.10436
3-jpg.10437
4-jpg.10438
5-jpg.10439
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
Download
Openvix 3.0 Build 600 Greek mod backup by kalemis vusolo2
Bootlogos:
Thanks to OPENVIX Team for very good stable image
What more installed ?
A) Greek language
B) 3 very good panels VIX , New menu & Ts panel
C) fixed 11823 frequency in Hotbird 13E
D)GST_SUBTITLE_ENCODING added for you can use more more subtitle formats than UTF-8, big thanks to athoik
E) 2 cams cccam and mgcamd
F) 2 Skins
G) and many Greek plugins
here is some fotos from image
http://img849.imageshack.us/img849/8885/backupx.jpg
Download link
Comming soon more Greek mod images by Kalemis ​
Online update available to v. 2.0.1 rev. A​
what is new ?
NEW: Support to NTFS usb sticks and external hdd. You can map your NTFS devices in Devices Manager: Main menu -> Black Hole App's -> Device Manager
Fix a bug in Parental Control that cause a GSD at pin input
Fix Main label translation in Bh Speed Up
Update Open Web Interface (Openwebif)
NEW: Add image rev. in About. The rev. will increase at every available update. In this way you can easly know what image version and update revision is installed in your box: Main Menu -> Information About.
PLEASE UPDATE !!
ItalySat SVN 84 - Online Now
=============== Date: 28/02/2013, SVN 084 ==============
**************** NEXT RELEASE **************
Tutti gli update presenti dalla SVN 077
Merge Enigma2 con OpenPLI 19/13 ore 21:00
Merge Oe con OpenPLI 19/13 ore 21:00
Added and fix inadyn with package inadyn-mt
New wifi driver Ralink 5572 and removed old Ralink driver
*Comprende ('RT2870/3070/8070/3370/3572/5370/5372/5572')
Added Brightness setup for Gigablue UE
Added in the keyboard, function for choise the button CH +/-
Added AFP mount (Apple mount - Mac OS X to Box)
Fix manual install package
Fix Italian translation in DTT searching
Beta: fix crash DTT for Dreambox
New Driver for Gigablue
Black-Hole v.2.0.1 rev.A Greek mod Backup by Kalemis
Bootlogos:
Thanks to Βlack Ηole Team for very good stable image
A) Greek language
B) 3 very good panels Black Hole , New menu & Ts panel
D) fixed time zone
E)GST_SUBTITLE_ENCODING added for you can use more more subtitle formats than UTF-8, big thanks to athoik
F) 2 cams cccam and mgcamd
G) latest drivers vuplus-dvb-modules-vusolo2-3.3.6-4.4.3-20130218
H) and many Greek plugins
http://img191.imageshack.us/img191/741/menu1n.jpg
http://img545.imageshack.us/img545/7892/cccamg.jpg
http://img32.imageshack.us/img32/5315/mgcamd.jpg
Download link
