Panasonic TV line-up 2013
vas_papavas
21 December 2010
8,849
Panasonic TC-P65S60
http://shop.panasonic.com/shop/model/TC-P65S60
gzoun
8 March 2008
1,958
Αθήνα-Μενίδι
First Panasonic 2013 Plasma TV (S60) Spotted On US Web Store
The model in question is the Viera TC-P65S60, which was first spotted by keen AV enthusiasts on Panasonic USA’s offical web store some time over the Christmas holidays. Exact specifications remain sketchy, but we will attempt to flesh out the plasma based on what little information that was posted on the product page.
The TC-P65S60 forms part of the Panasonic S60 series, from which we can deduce two things. First, the absence of the character “T” (which stands for Three-D) from the series number means that this is a television that doesn’t have 3D capabilities. Second, the Japanese brand is going to use the figure six in its 2013 range of HDTV products, for example the UT60, ST60, GT60 and VT60.
As is standard with most HDTVs these days, the Panasonic TC-P65S60 will sport a full HD 1080p native screen resolution. Screen size is 65 inches, the largest offered on the manufacturer’s consumer-grade plasma TVs. From what we’ve seen of the pictures in the image gallery, the design is sleek and modern. The plasma screen is framed by a relatively thin, polished black bezel which is in turn adorned by a silver strip along the top and bottom borders, adding a touch of class to the whole setup. The pedestal stand is a rectangular, glossy black affair.
WiFi connectivity is built-in, granting users convenient access to Panasonic’s Smart Viera internet-connected portal. An intriguing technology purportedly implemented on the 65S60 is the “Touch Pen” feature, which may be a digital input system previously available on the firm’s professional plasmas. We hope that this allows viewers to operate the TV (e.g. change channels, surf online) wirelessly from their sofa, instead of having to walk up close to the screen to scribble on a touch-sensitive panel.
Given that the TC-P65S60 is specced to have 600Hz sub-field drive rather than 2000Hz or 2500Hz focused field drive (FFD) used to market the Panasonic’s more advanced 2012 plasma televisions, it’s not entirely clear whether the S60 will be equipped with the firm’s next-generation (16G) panels or not. We’ll bring you more updates as we learn more at next year’s CES and Panasonic Convention.
http://www.hdtvtest.co.uk/news/panasonic-2013-plasma-tv-201212272494.htm
Gal'en
2 July 2012
8,888
Αθηνα
Εγω παλι γιατι βγαζω αλλα συμπερασματα σε σχεση με το σαιτ?
Κρινοντας απο την πολιτικη της εταιριας φετος, που εβαλε 3d στις πιο φτηνες σειρες
αλλα και απο τη χρηση του σε ολο και μικροτερες ιντσες, μου φαινεται πιο πιθανο
του χρονου να εχουν ολα τα μοντελα της 3d και γι'αυτο δεν θα χρειαζεται πλεον το
γραμμα Τ. Αν φτασει να βγαλει παλι τη σειρα s ανευ
και μαλιστα σε τετοιες ιντσες θα εκπλαγω πολυ.
Και θα νευριασω κιολας. Περιμεναν να παρω εγω τηλεοραση που το εχω γραμμενο, για να
διαχωρισουν τη θεση τους απο αυτο?
JL_?
19 September 2008
15,415
Terra
Σύμφωνα με ανεπιβεβαίωτες φήμες, αναμένεται στη φετινή γκάμα Plasma και LCD να ακολουθήσει και η Panasonic το παράδειγμα των υπoλοίπων κατασκευαστών, όπου οι δικοί της επεξεργαστές εικόνας/ελέγχου θα μπαίνουν μόνο στις ναυαρχίδες της και οι υπόλοιπες σειρές θα βολεύονται με ολοκληρωμένα των γνωστών Ταϊβανέζων κατασκευαστών (MediaTek για την περίπτωση)...
JL_?
19 September 2008
15,415
Terra
Moνον στις VT60 δηλαδη ?
Mάλλον VT/GT από Plasma και WT/DT από LCD...
Υπομονή, μήπως αναφέρουν τίποτα σχετικό στην CES, αλλιώς θα μάθουμε σίγουρα το αργότερο μόλις κυκλοφορήσουν...
polakis
19 September 2008
2,792
Ναι αυτο το εχει πει προ καιρου ο avjunkie στο highdefjunkies. Θα τα δουμε ολα σε λιγες μερες στην ces. Εχει πει οτι φετος η vt60 θα εχει μεγαλη διαφορα απο την st60 πχ...
Yperion
21 June 2006
43,515
BVR (Beyond Visual Range)
Πολύ σωστή κίνηση και για το παθητικό και για την συνεργασία στο smart tv.
Επιτέλους η Panasonic δείχνει να βρίσκεται στον σωστό δρόμο , λίγη βελτίωση και στον σχεδιασμό χρειάζεται και οι Κορεάτες θα αρχίσουν να χάνουν τον ύπνο τους.
xavito
29 October 2008
8,993
PANASONIC UNVEILS ENHANCED 2013 SMART VIERA PLASMA HDTV LINEUP
ZT60 Series,VT60 Series,ST60 Series,S60 Series,X60 Series
http://www2.panasonic.com/webapp/wcs/stores/servlet/prModelDetail?storeId=11301&catalogId=13251&itemId=692007&modelNo=Content01072013040339024&surfModel=Content01072013040339024
PANASONIC UNVEILS STUNNING DESIGN INNOVATIONS AND CUTTING-EGDE FEATURES ON VIERA 2013 LED/LCD MODELS
WT60 Series,DT60 Series,ET60 Series,E60 Series,EM60 Series,XM6 Series,B6 Series
http://www2.panasonic.com/webapp/wcs/stores/servlet/prModelDetail?storeId=11301&catalogId=13251&itemId=692503&modelNo=Content01072013040213924&surfModel=Content01072013040213924
source:[Panasonic USA Pressroom]
evanfotis
26 March 2008
5,489
IPS panel from LG Display... Στις πλάσμα επανέρχεται η ΖΤ φεύγουν οι GT, καλό οτι υπάρχει πάλι σκέτη η S.
czoun
29 November 2007
7,734
Απάντηση: Re: Panasonic TV line-up 2013
Απ' όλες τις παραπάνω, μόνο στην ΖT60 υπάρχει ένδειξη/δυνατότητα ISFccc Calibration Mode (This function is exclusively for calibrator use. It is not intended for use by ordinary consumers.)...
...αν μας διαβάζει κανένας επαγγελματίας ISF , ας μας πει δυο λόγια γι' αυτό και τι διαφορά έχει από τα άλλα ρυθμιστικά που υπάρχουν στις υπόλοιπες... :D
